Temporarily increases a light's brightness when motion is detected
I had ChatGPT made this:
blueprint:
  name: Motion - Temporary Brightness Increase With Restore
  description: >
    Temporarily increases a light's brightness when motion is detected.
    Only runs if the light is already ON.
    After the configured no-motion timeout, the original state
    (brightness, color, color temperature, etc.) is restored.
  domain: automation
  input:
    motion_sensor:
      description: Binary motion sensor that triggers the automation
      selector:
        entity:
          domain: binary_sensor
          device_class: motion
    target_light:
      description: The light to temporarily brighten
      selector:
        entity:
          domain: light
    brightness_pct:
      name: Temporary Brightness (%)
      description: Brightness level to set during motion
      default: 80
      selector:
        number:
          min: 1
          max: 100
          unit_of_measurement: "%"
    no_motion_wait:
      name: No Motion Timeout (seconds)
      description: Time without motion before restoring original state
      default: 120
      selector:
        number:
          min: 5
          max: 3600
          unit_of_measurement: seconds
mode: restart
max_exceeded: silent
variables:
  scene_id: "motion_restore_{{ this.context.id }}"
  - platform: state
    entity_id: !input motion_sensor
    to: "on"
condition:
  - condition: state
    entity_id: !input target_light
    state: "on"
  # Snapshot current light state
  - service: scene.create
      scene_id: "{{ scene_id }}"
      snapshot_entities:
        - !input target_light
  # Set temporary brightness
  - service: light.turn_on
      brightness_pct: !input brightness_pct
  # Wait until motion turns off
  - wait_for_trigger:
      - platform: state
        to: "off"
    timeout:
      seconds: !input no_motion_wait
    continue_on_timeout: false
  # Ensure full no-motion duration
  - delay:
  # Restore original state
  - service: scene.turn_on
      entity_id: "scene.{{ scene_id }}"
Posting code that is written by others is a bit frowned upon, mostly because if the codebase changes, you will not be able to support it.
It may actually be best to use it yourself, but not share it. It would be up to the author to share it .
That aside, I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
You need to be a trust level ‘member’ to edit a post. Understanding Discourse Trust Levels
If you can’t edit, I would load a link into a second post.
