Hi all,
Since some years I have a small NAS/Server build with a small NUC / SBC running Openmediavault (OMV) and everything I needed in docker incl. Home Assistant.
I have / had fun with tinkering finding solutions to my problems etc… But as life goes forward time becomes a valuable ressource and I tend to spend it less and less alone with the PC.
I delved a bit into the new Home Assistant Interface and saw that basically all the dockers / services I am using exist as “plugins / extensions”. I understand these are just curated docker instances but with a nice and easy interface.
My needs are quite simple:
- Home Assistant for controlling my home (automating will come once I have moved)
- Nextcloud to have a secondary backup of my most important files and stuff (right now on a separate SSD inside the NUC i use as a server)
- Adguard (or just a general adblocker)
- Plex (not used since I have streaming services, but surely a nice backup if internet should one day fail)
- jDownloader for when there are multiple big downloads to queue
- A data grave HDD which is there to store the Plex Movies and be a place for backups / Fotos. I might try to get a second one to be safe.
Regarding Adguard and Plex HASSOS is allready quite ready (and super neat) it seems, but for the rest I am not so sure, as I mostly read about integrations.
Would you see a solution / recommend me to do the switch once I move / rebuild my whole setup ?
I don’t really need / use advances NAS / RAID stuff, as I never needed / learnt how to best use it and am more anxious to mess things up if there isn’t a GUI protecting me from the biggest mistakes…
I would love your input on this to learn more and have the best possible solution at the end. HASS made so much thing possible and I hope it will make even more stuff happen in the future.
