Tempur-Pedic Sleep Tracker AI
Is the CO2, humidity, temperature, and VOC sensor information coming from this integration or are these stats coming from a separate air quality sensor? Don’t seem to have these stats.
The Tempur ProSmart (STS-60) devices got rid of the API I was using to pull this data, so if you have one that’ll be why you don’t see them. The older STS-40 Sleeptracker modules had a convenient API that could be called regularly to get the values.
Thanks Richard, is the STS-60 API/integration done or is there a chance it will come back? Alexa integration is not working either. I called support and they blamed it on the Amazon servers but it has been down over a month.
The STS-60 Alexa connection is back up, maybe the API is available again.
@richardhopton Do you know if there’s a way to get the sleep data, how much time spent in each sleep stage, etc. from the sleeptracker API? And I can’t find a web site to even register to work with the API. Can you point me in that direction?
Any further updates here? I have the activebreeze and was hoping to automate. Happy to help how I can.
