Yes, that’s where I can see that startup is looping.
LOGS:
> 2019-04-05 14:37:55 INFO (MainThread) [homeassistant.loader] Loaded gpslogger from homeassistant.components.gpslogger,
> 2019-04-05 14:37:55 INFO (MainThread) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook,
> 2019-04-05 14:37:55 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http,
> 2019-04-05 14:37:55 INFO (MainThread) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant,
> 2019-04-05 14:37:55 INFO (MainThread) [homeassistant.loader] Loaded tts from homeassistant.components.tts,
> 2019-04-05 14:37:55 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend,
> 2019-04-05 14:37:55 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api,
> 2019-04-05 14:37:55 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api,
> 2019-04-05 14:37:55 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log,
> 2019-04-05 14:37:55 INFO (MainThread) [homeassistant.loader] Loaded auth from homeassistant.components.auth,
> 2019-04-05 14:37:55 INFO (MainThread) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding,
> 2019-04-05 14:37:55 INFO (MainThread) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded script from homeassistant.components.script,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded group from homeassistant.components.group,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded zone from homeassistant.components.zone,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded telegram_bot from homeassistant.components.telegram_bot,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded yeelight from homeassistant.components.yeelight,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded stream from homeassistant.components.stream,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded utility_meter from homeassistant.components.utility_meter,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded image_processing from homeassistant.components.image_processing,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded camera from homeassistant.components.camera,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded input_select from homeassistant.components.input_select,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded influxdb from homeassistant.components.influxdb,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded folder_watcher from homeassistant.components.folder_watcher,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded weather from homeassistant.components.weather,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded input_boolean from homeassistant.components.input_boolean,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded input_text from homeassistant.components.input_text,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded notify from homeassistant.components.notify,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded sabnzbd from homeassistant.components.sabnzbd,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded climate from homeassistant.components.climate,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded automation from homeassistant.components.automation,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded config from homeassistant.components.config,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded hass_opensprinkler from custom_components.hass_opensprinkler,
> 04-05 14:37:56 WARNING (MainThread) [homeassistant.loader] You are using a custom component for hass_opensprinkler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded map from homeassistant.components.map,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded input_number from homeassistant.components.input_number,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded alarm_control_panel from homeassistant.components.alarm_control_panel,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded switch from homeassistant.components.switch,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded light from homeassistant.components.light,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded logger from homeassistant.components.logger,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded alert from homeassistant.components.alert,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded cast from homeassistant.components.cast,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized,
> 2019-04-05 14:37:56 INFO (MainThread) [homeassistant.setup] Setting up logger,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded notify from homeassistant.components.notify,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded weather from homeassistant.components.weather,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded switch from homeassistant.components.switch,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded group from homeassistant.components.group,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded telegram_bot from homeassistant.components.telegram_bot,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded utility_meter from homeassistant.components.utility_meter,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded zone from homeassistant.components.zone,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded alarm_control_panel from homeassistant.components.alarm_control_panel,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded sabnzbd from homeassistant.components.sabnzbd,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded yeelight from homeassistant.components.yeelight,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded map from homeassistant.components.map,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded auth from homeassistant.components.auth,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded alert from homeassistant.components.alert,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded image_processing from homeassistant.components.image_processing,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded camera from homeassistant.components.camera,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded input_text from homeassistant.components.input_text,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded automation from homeassistant.components.automation,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded tts from homeassistant.components.tts,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded gpslogger from homeassistant.components.gpslogger,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded logger from homeassistant.components.logger,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded folder_watcher from homeassistant.components.folder_watcher,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded hass_opensprinkler from custom_components.hass_opensprinkler,
> 04-05 14:38:02 WARNING (MainThread) [homeassistant.loader] You are using a custom component for hass_opensprinkler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded config from homeassistant.components.config,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded cast from homeassistant.components.cast,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded script from homeassistant.components.script,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded light from homeassistant.components.light,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded input_select from homeassistant.components.input_select,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded climate from homeassistant.components.climate,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded input_number from homeassistant.components.input_number,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded stream from homeassistant.components.stream,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded input_boolean from homeassistant.components.input_boolean,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded influxdb from homeassistant.components.influxdb,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized,
> 2019-04-05 14:38:02 INFO (MainThread) [homeassistant.setup] Setting up logger,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded tts from homeassistant.components.tts,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded logger from homeassistant.components.logger,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded gpslogger from homeassistant.components.gpslogger,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded notify from homeassistant.components.notify,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded light from homeassistant.components.light,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded group from homeassistant.components.group,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded script from homeassistant.components.script,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded input_text from homeassistant.components.input_text,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded alert from homeassistant.components.alert,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded hass_opensprinkler from custom_components.hass_opensprinkler,
> 04-05 14:38:09 WARNING (MainThread) [homeassistant.loader] You are using a custom component for hass_opensprinkler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded influxdb from homeassistant.components.influxdb,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded camera from homeassistant.components.camera,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded utility_meter from homeassistant.components.utility_meter,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded folder_watcher from homeassistant.components.folder_watcher,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded map from homeassistant.components.map,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded input_select from homeassistant.components.input_select,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded sabnzbd from homeassistant.components.sabnzbd,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded telegram_bot from homeassistant.components.telegram_bot,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded zone from homeassistant.components.zone,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded weather from homeassistant.components.weather,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api,
> 2019-04-05 14:38:09 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded auth from homeassistant.components.auth,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded climate from homeassistant.components.climate,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded cast from homeassistant.components.cast,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded config from homeassistant.components.config,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded input_boolean from homeassistant.components.input_boolean,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded switch from homeassistant.components.switch,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded input_number from homeassistant.components.input_number,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded alarm_control_panel from homeassistant.components.alarm_control_panel,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded yeelight from homeassistant.components.yeelight,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded stream from homeassistant.components.stream,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded automation from homeassistant.components.automation,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded image_processing from homeassistant.components.image_processing,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized,
> 2019-04-05 14:38:10 INFO (MainThread) [homeassistant.setup] Setting up logger,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded weather from homeassistant.components.weather,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded logger from homeassistant.components.logger,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded api from homeassistant.components.api,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded http from homeassistant.components.http,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded auth from homeassistant.components.auth,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded folder_watcher from homeassistant.components.folder_watcher,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded script from homeassistant.components.script,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded group from homeassistant.components.group,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded input_boolean from homeassistant.components.input_boolean,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded zone from homeassistant.components.zone,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded map from homeassistant.components.map,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded telegram_bot from homeassistant.components.telegram_bot,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded tts from homeassistant.components.tts,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded camera from homeassistant.components.camera,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded gpslogger from homeassistant.components.gpslogger,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded utility_meter from homeassistant.components.utility_meter,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded alarm_control_panel from homeassistant.components.alarm_control_panel,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded config from homeassistant.components.config,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded yeelight from homeassistant.components.yeelight,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded notify from homeassistant.components.notify,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded stream from homeassistant.components.stream,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded climate from homeassistant.components.climate,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded input_text from homeassistant.components.input_text,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded switch from homeassistant.components.switch,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded image_processing from homeassistant.components.image_processing,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded influxdb from homeassistant.components.influxdb,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded light from homeassistant.components.light,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded alert from homeassistant.components.alert,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded input_number from homeassistant.components.input_number,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded cast from homeassistant.components.cast,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded hass_opensprinkler from custom_components.hass_opensprinkler,
> 04-05 14:38:17 WARNING (MainThread) [homeassistant.loader] You are using a custom component for hass_opensprinkler which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded sabnzbd from homeassistant.components.sabnzbd,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded automation from homeassistant.components.automation,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.loader] Loaded input_select from homeassistant.components.input_select,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.bootstrap] Home Assistant core initialized,
> 2019-04-05 14:38:17 INFO (MainThread) [homeassistant.setup] Setting up logger,
