EDIT: Nevermind I think I found something related… Missing tensorflow wheel for Alpine 3.13 · Issue #48569 · home-assistant/core · GitHub
EDIT AGAIN: Actually I have no idea… maybe it’s not related…
Since upgrading to 2021.4.1 (I believe that’s when it started). I am getting this error and my Tensorflow image processing doesn’t work.
I’m running 2021.4.5 on Debian 10 Supervised.
I coming from a longtime VENV install so I haven’t had to do much troubleshooting in a supervised environment, so I’m not really sure the best way to troubleshoot/reinstall packages in supervised… anyone have any suggestions?
2021-04-18 12:44:09 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/tensorflow/image_processing.py", line 176, in tensorflow_hass_start
model(input_tensor)
File "/usr/local/lib/python3.8/site-packages/tensorflow/python/eager/def_function.py", line 780, in __call__
result = self._call(*args, **kwds)
File "/usr/local/lib/python3.8/site-packages/tensorflow/python/eager/def_function.py", line 823, in _call
self._initialize(args, kwds, add_initializers_to=initializers)
File "/usr/local/lib/python3.8/site-packages/tensorflow/python/eager/def_function.py", line 696, in _initialize
self._stateful_fn._get_concrete_function_internal_garbage_collected( # pylint: disable=protected-access
File "/usr/local/lib/python3.8/site-packages/tensorflow/python/eager/function.py", line 2855, in _get_concrete_function_internal_garbage_collected
graph_function, _, _ = self._maybe_define_function(args, kwargs)
File "/usr/local/lib/python3.8/site-packages/tensorflow/python/eager/function.py", line 3213, in _maybe_define_function
graph_function = self._create_graph_function(args, kwargs)
File "/usr/local/lib/python3.8/site-packages/tensorflow/python/eager/function.py", line 3065, in _create_graph_function
func_graph_module.func_graph_from_py_func(
File "/usr/local/lib/python3.8/site-packages/tensorflow/python/framework/func_graph.py", line 986, in func_graph_from_py_func
func_outputs = python_func(*func_args, **func_kwargs)
File "/usr/local/lib/python3.8/site-packages/tensorflow/python/eager/def_function.py", line 600, in wrapped_fn
return weak_wrapped_fn().__wrapped__(*args, **kwds)
File "/usr/local/lib/python3.8/site-packages/tensorflow/python/framework/func_graph.py", line 973, in wrapper
raise e.ag_error_metadata.to_exception(e)
NotImplementedError: in user code:
/usr/src/homeassistant/homeassistant/components/tensorflow/image_processing.py:91 detect_fn *
prediction_dict = model.predict(image, shapes)
/config/tensorflow/object_detection/meta_architectures/faster_rcnn_meta_arch.py:827 predict *
prediction_dict.update(
/config/tensorflow/object_detection/meta_architectures/faster_rcnn_meta_arch.py:1003 _predict_second_stage *
prediction_dict = self._box_prediction(rpn_features_to_crop,
/config/tensorflow/object_detection/meta_architectures/faster_rcnn_meta_arch.py:1065 _box_prediction *
flattened_proposal_feature_maps = (
/config/tensorflow/object_detection/meta_architectures/faster_rcnn_meta_arch.py:1958 _compute_second_stage_input_feature_maps *
cropped_regions = self._flatten_first_two_dimensions(
/config/tensorflow/object_detection/utils/spatial_transform_ops.py:520 multilevel_matmul_crop_and_resize *
return multilevel_roi_align(images,
/config/tensorflow/object_detection/utils/spatial_transform_ops.py:349 multilevel_roi_align *
feature_coordinates = ravel_indices(feature_grid_y, feature_grid_x,
/config/tensorflow/object_detection/utils/spatial_transform_ops.py:187 ravel_indices *
batch_dim_indices = (
/usr/local/lib/python3.8/site-packages/tensorflow/python/util/dispatch.py:201 wrapper **
return target(*args, **kwargs)
/usr/local/lib/python3.8/site-packages/tensorflow/python/ops/array_ops.py:3041 ones
output = _constant_if_small(one, shape, dtype, name)
/usr/local/lib/python3.8/site-packages/tensorflow/python/ops/array_ops.py:2732 _constant_if_small
if np.prod(shape) < 1000:
<__array_function__ internals>:5 prod
/usr/local/lib/python3.8/site-packages/numpy/core/fromnumeric.py:3030 prod
return _wrapreduction(a, np.multiply, 'prod', axis, dtype, out,
/usr/local/lib/python3.8/site-packages/numpy/core/fromnumeric.py:87 _wrapreduction
return ufunc.reduce(obj, axis, dtype, out, **passkwargs)
/usr/local/lib/python3.8/site-packages/tensorflow/python/framework/ops.py:845 __array__
raise NotImplementedError(
NotImplementedError: Cannot convert a symbolic Tensor (MultiLevelMatMulCropAndResize/MultiLevelRoIAlign/strided_slice_5:0) to a numpy array. This error may indicate that you're trying to pass a Tensor to a NumPy call, which is not supported
I tried uninstalling and reinstalling numpy but I get this on reinstall:
Downloading numpy-1.20.2.zip (7.8 MB)
|████████████████████████████████| 7.8 MB 2.2 MB/s
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing wheel metadata ... error
ERROR: Command errored out with exit status 1:
command: /usr/local/bin/python /usr/local/lib/python3.8/site-packages/pip/_vendor/pep517/_in_process.py prepare_metadata_for_build_wheel /tmp/tmp3xrt62cm
cwd: /tmp/pip-install-pgas2zyk/numpy
Complete output (226 lines):
Processing numpy/random/_bounded_integers.pxd.in
Processing numpy/random/mtrand.pyx
Processing numpy/random/_pcg64.pyx
Processing numpy/random/bit_generator.pyx
Processing numpy/random/_sfc64.pyx
Processing numpy/random/_common.pyx
Processing numpy/random/_bounded_integers.pyx.in
Processing numpy/random/_philox.pyx
Processing numpy/random/_generator.pyx
Processing numpy/random/_mt19937.pyx
Cythonizing sources
blas_opt_info:
blas_mkl_info:
customize UnixCCompiler
libraries mkl_rt not found in ['/usr/local/lib', '/usr/lib']
NOT AVAILABLE
blis_info:
libraries blis not found in ['/usr/local/lib', '/usr/lib']
NOT AVAILABLE
openblas_info:
libraries openblas not found in ['/usr/local/lib', '/usr/lib']
NOT AVAILABLE
atlas_3_10_blas_threads_info:
Setting PTATLAS=ATLAS
libraries tatlas not found in ['/usr/local/lib', '/usr/lib']
NOT AVAILABLE
atlas_3_10_blas_info:
libraries satlas not found in ['/usr/local/lib', '/usr/lib']
NOT AVAILABLE
atlas_blas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in ['/usr/local/lib', '/usr/lib']
NOT AVAILABLE
atlas_blas_info:
libraries f77blas,cblas,atlas not found in ['/usr/local/lib', '/usr/lib']
NOT AVAILABLE
blas_info:
libraries blas not found in ['/usr/local/lib', '/usr/lib']
NOT AVAILABLE
blas_src_info:
NOT AVAILABLE
NOT AVAILABLE
non-existing path in 'numpy/distutils': 'site.cfg'
lapack_opt_info:
lapack_mkl_info:
NOT AVAILABLE
openblas_lapack_info:
NOT AVAILABLE
openblas_clapack_info:
libraries openblas,lapack not found in ['/usr/local/lib', '/usr/lib']
NOT AVAILABLE
flame_info:
libraries flame not found in ['/usr/local/lib', '/usr/lib']
NOT AVAILABLE
atlas_3_10_threads_info:
libraries lapack_atlas not found in /usr/local/lib
libraries tatlas,tatlas not found in /usr/local/lib
libraries lapack_atlas not found in /usr/lib
libraries tatlas,tatlas not found in /usr/lib
<class 'numpy.distutils.system_info.atlas_3_10_threads_info'>
NOT AVAILABLE
atlas_3_10_info:
libraries satlas,satlas not found in /usr/local/lib
libraries satlas,satlas not found in /usr/lib
<class 'numpy.distutils.system_info.atlas_3_10_info'>
NOT AVAILABLE
atlas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib
<class 'numpy.distutils.system_info.atlas_threads_info'>
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in /usr/local/lib
libraries f77blas,cblas,atlas not found in /usr/lib
<class 'numpy.distutils.system_info.atlas_info'>
NOT AVAILABLE
lapack_info:
libraries lapack not found in ['/usr/local/lib', '/usr/lib']
NOT AVAILABLE
lapack_src_info:
NOT AVAILABLE
NOT AVAILABLE
numpy_linalg_lapack_lite:
FOUND:
language = c
define_macros = [('HAVE_BLAS_ILP64', None), ('BLAS_SYMBOL_SUFFIX', '64_')]
running dist_info
running build_src
build_src
building py_modules sources
creating build
creating build/src.linux-x86_64-3.8
creating build/src.linux-x86_64-3.8/numpy
creating build/src.linux-x86_64-3.8/numpy/distutils
building library "npymath" sources
Could not locate executable gfortran
Could not locate executable f95
Could not locate executable ifort
Could not locate executable ifc
Could not locate executable lf95
Could not locate executable pgfortran
Could not locate executable nvfortran
Could not locate executable f90
Could not locate executable f77
Could not locate executable fort
Could not locate executable efort
Could not locate executable efc
Could not locate executable g77
Could not locate executable g95
Could not locate executable pathf95
Could not locate executable nagfor
Could not locate executable frt
don't know how to compile Fortran code on platform 'posix'
Running from numpy source directory.
setup.py:485: UserWarning: Unrecognized setuptools command, proceeding with generating Cython sources and expanding templates
run_build = parse_setuppy_commands()
/tmp/pip-install-pgas2zyk/numpy/numpy/distutils/system_info.py:1989: UserWarning:
Optimized (vendor) Blas libraries are not found.
Falls back to netlib Blas library which has worse performance.
A better performance should be easily gained by switching
Blas library.
if self._calc_info(blas):
Blas (http://www.netlib.org/blas/) libraries not found.
Directories to search for the libraries can be specified in the
numpy/distutils/site.cfg file (section [blas]) or by setting
the BLAS environment variable.
Blas (http://www.netlib.org/blas/) sources not found.
Directories to search for the sources can be specified in the
numpy/distutils/site.cfg file (section [blas_src]) or by setting
the BLAS_SRC environment variable.
/tmp/pip-install-pgas2zyk/numpy/numpy/distutils/system_info.py:1849: UserWarning:
Lapack (http://www.netlib.org/lapack/) libraries not found.
numpy/distutils/site.cfg file (section [lapack]) or by setting
the LAPACK environment variable.
return getattr(self, '_calc_info_{}'.format(name))()
Lapack (http://www.netlib.org/lapack/) sources not found.
numpy/distutils/site.cfg file (section [lapack_src]) or by setting
the LAPACK_SRC environment variable.
/usr/local/lib/python3.8/distutils/dist.py:274: UserWarning: Unknown distribution option: 'define_macros'
warnings.warn(msg)
File "/usr/local/lib/python3.8/site-packages/pip/_vendor/pep517/_in_process.py", line 280, in <module>
main()
File "/usr/local/lib/python3.8/site-packages/pip/_vendor/pep517/_in_process.py", line 263, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/usr/local/lib/python3.8/site-packages/pip/_vendor/pep517/_in_process.py", line 133, in prepare_metadata_for_build_wheel
return hook(metadata_directory, config_settings)
File "/tmp/pip-build-env-us8uxf2i/overlay/lib/python3.8/site-packages/setuptools/build_meta.py", line 157, in prepare_metadata_for_build_wheel
self.run_setup()
File "/tmp/pip-build-env-us8uxf2i/overlay/lib/python3.8/site-packages/setuptools/build_meta.py", line 248, in run_setup
super(_BuildMetaLegacyBackend,
File "/tmp/pip-build-env-us8uxf2i/overlay/lib/python3.8/site-packages/setuptools/build_meta.py", line 142, in run_setup
exec(compile(code, __file__, 'exec'), locals())
File "setup.py", line 513, in <module>
setup_package()
File "setup.py", line 505, in setup_package
setup(**metadata)
File "/tmp/pip-install-pgas2zyk/numpy/numpy/distutils/core.py", line 169, in setup
return old_setup(**new_attr)
File "/tmp/pip-build-env-us8uxf2i/overlay/lib/python3.8/site-packages/setuptools/__init__.py", line 165, in setup
return distutils.core.setup(**attrs)
File "/usr/local/lib/python3.8/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/local/lib/python3.8/distutils/dist.py", line 966, in run_commands
self.run_command(cmd)
File "/usr/local/lib/python3.8/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/tmp/pip-build-env-us8uxf2i/overlay/lib/python3.8/site-packages/setuptools/command/dist_info.py", line 31, in run
egg_info.run()
File "/tmp/pip-install-pgas2zyk/numpy/numpy/distutils/command/egg_info.py", line 24, in run
self.run_command("build_src")
File "/usr/local/lib/python3.8/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/tmp/pip-install-pgas2zyk/numpy/numpy/distutils/command/build_src.py", line 144, in run
self.build_sources()
File "/tmp/pip-install-pgas2zyk/numpy/numpy/distutils/command/build_src.py", line 155, in build_sources
self.build_library_sources(*libname_info)
File "/tmp/pip-install-pgas2zyk/numpy/numpy/distutils/command/build_src.py", line 288, in build_library_sources
sources = self.generate_sources(sources, (lib_name, build_info))
File "/tmp/pip-install-pgas2zyk/numpy/numpy/distutils/command/build_src.py", line 378, in generate_sources
source = func(extension, build_dir)
File "numpy/core/setup.py", line 676, in get_mathlib_info
raise RuntimeError("Broken toolchain: cannot link a simple C program")
RuntimeError: Broken toolchain: cannot link a simple C program
ERROR: Command errored out with exit status 1: /usr/local/bin/python /usr/local/lib/python3.8/site-packages/pip/_vendor/pep517/_in_process.py prepare_metadata_for_build_wheel /tmp/tmp3xrt62cm Check the logs for full command output.
