I have read many things about Tensorflow with hassbian, but it is not so clear about hassio and Tensorflow.
Is it possible to use it with hassio (with last version of hassio 0.86.3 ?
Is there any other face recognition with hassio ? Which one is the best to recognize precise face (with database)
Hello @M203 !
Thanks for sharing this link
I am willing to stay focus on Tensorflow (maybe OpenCV), and also looking at running it on a separate raspberry.
the tricky part should be to find a way to link a door automation with hassio, send a request to the other raspberry to test the jpg file to make a face recognition and send back a response to the hassio with a text var of the person who was identify
I thought you may be interested in knowing that Jason Hunter has uploaded a TensorFlow installer to his Hassio Addons repository! Do note this is only for amd64 platforms (it works perfectly with my Intel i7 NUC)!
Should it work on Pentium G3220? I can’t get it working - when I try to include image_processing in configuration.yaml, hass doesn’t start. Logs doesn’t show anything about tensor flow. Where can I find any solution for it?
Seemed to work for me, running hassio on a nuc, but when I call the scan service, it seems like nothing happens. I tried specifying a file_out file but that doesn’t get generated. No errors either. Hmm.
Ok, solved. I migrated from old Pentium to my spare supermicro server with Xeon E3-1220 and now it works like a charm. Now I have plenty of power. And power usage is lower about 15 W.
