Tenvis TH661 IP Camera, Anybody got this working?
Hi, just trying to get my camera working. Have tried most settings I have seen in other threads but cant get a static or streamed image.
Anybody using a Tenvis TH661 camera?
Regards, Dave
I’m working on this now. Have you gotten further?
using a TH692 but installed on a BlueIris server, for me it’s more convenient to do video processing on another machine. then you just type the address of your ip video server, just search for the dedicated topic on this forum if you need more info.
Hi getting there
For video feed use the following
stream:
camera:
  - platform: generic
    still_image_url: http://192.168.X.XXX/cgi-bin/snapshot.cgi
    stream_source: rtsp://NAME:[email protected]:554/11
    username: NAME
    password: PASSWORD
    authentication: basic
change the X for your IP address
I now get a video stream, but I cant find the correct path for the still image, so I get an error in the log file
Let me know if that works for you.
Regards Dave
This worked for me. I was just getting stills prior. Thank you. Gonna play around with pan/tilt to see if I can get that working.
Please let me know how you get on, I cant get the still image to work.
I asked Tenvis “What is the correct url to view a still image”
There reply was “We do not provide this for customers” Not helpful
How did you get a still image to display?
Re Dave
I was using ffmpeg. I’m having the same problem now though. Will play around with it tomorrow.
Did you ever get the still picture working?
Sorry for late reply, but no, I contacted Tenvis and they said not.
Re Dave
Got it! Still image now works for me: see: /tmpfs/auto.jpg below
camera:
  - platform: generic
    still_image_url: http://userid:password@ip_address:XX/tmpfs/auto.jpg
    stream_source: rtsp://userid:password@ip_address:YY/11
XX= Web Port (default= 80)
YY= RTSP Port (default = 554)
Still image not working for me, so you are using :80/tmpfs/auto.jpg ?
Re Dave
@DaveTiff “sort of”, I changed the defaults. I am using 8092 for the http port.
TH661 HTTP&RTSP Setup
TH661 Code levels in next post (new users can only post one image at a time)
I found the “path” that worked for me here.
I “edited” the full URL string in my browser until I got it to work before committing it to my configuration.yaml file.
@DaveTiff
My TH661 code levels are:
TH661 Code Version
My TH661 software is totally different
Very interesting. That certainly explains why different folks are getting different results.
I picked potential “path” suspects from the list referenced above and was lucky enough to stumble upon one that worked for me.
These failed for me, one may work for you:
snapshot.cgi?
snapshot
jpg/image.jpg?size=3
You can quickly test each variation in your browser. Good luck… (there may be others to try hidden in the “path” list.)
Hi everyone,
I stumbled upon this thread trying to get this over the top chinese camera and thanks to you I was able to find the rtsp url to get an stream. I noticed that in this thread there is no data regarding the PTZ movement so here goes my findings…
By logging into the '90s web console of the camera (I don’t know if these work with the cameras that have the nice looking firmware) and using the Inspect option from chrome, network tab:
Hi Res feed: rtsp://username:password@IP:554/11
Lo Res feed: rtsp://username:password@IP:554/12
Audio codec is aac just in case you need it
Down Command:
http://username:password@IP:80/web/cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=down
Stop Command:
http://username:password@IP:80/web/cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=stop
Up Command:
http://username:password@IP:80/web/cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=up
Left Command:
http://username:password@IP:80/web/cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=left
Right Command:
http://username:password@IP:80/web/cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=right
Send To Home:
http://username:password@IP:80/web/cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=home
Go to Preset 0 (change the last digit zero for the one you are looking for)
http://username:password@IP:80/web/cgi-bin/hi3510/param.cgi?cmd=preset&-act=goto&-number=0
Set Preset 1 (replace one at the end with the number you want to call later)
http://username:password@IP:80/web/cgi-bin/hi3510/param.cgi?cmd=preset&-act=set&-status=1&-number=1
Do a “vertical scan” (with this command the camera goes full up&down and end in the position it was before starting the sweep:
http://username:password@IP:80/web/cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=vscan
Do a “horizontal scan” (with this command the camera goes full right&left and end in the position it was before starting the sweep:
http://username:password@IP:80/web/cgi-bin/hi3510/ptzctrl.cgi?-step=0&-act=hscan
And thats pretty much it…I hope it helps.
Cheers.
This works using a LOCAL ip only, but how do you view the same live camera video stream from external IP?
For example I use mangocam to record live camera video stream, but it asks for the camera details and all the ones i tried dont work
Home Assistant accesses the camera locally.
Enable remote access to Home Assistant to access your camera externally.
I use DuckDNS + NGINX for remote access. Many use Nabu Casa.
So I had a box of two Tenvis TH661 cameras. They are ancient (bought originally in 2019), but they have RTSP support. I have been working on project to get Frigate and Home Assistant up with a medley of webcams, many close to a decade old, and I was able to incorporate these dated TH661 models working in frigate. Even got the PTZ working!
They DO NOT have a port :80 http web interface, and the Tenvisty iOS app has no facility to re-configure ports like those that are depicted in this thread for some h/w versions of the TH661. The TenVis website indicates that a hardware version 4 is still for sale under the TH661 name.
Anyway, I documented my findings on a blog post: Very Old Tenvis TH611 Webcam Working With Frigate - Even PTZ | David Crook
Here is the important snippets for a frigate config, with the onvif section of the cameras config being the part that enables the pan and tilt controls in Frigate.
go2rtc:
  streams:
    tenvis_great_room: "rtsp://admin:[email protected]:554/11"
    tenvis_great_room_sub: "rtsp://admin:[email protected]:554/12"
cameras:
  tenvis_great_room:
    enabled: true
    ffmpeg:
      inputs:
        - path: rtsp://127.0.0.1:8554/tenvis_great_room_sub
          input_args: preset-rtsp-restream
          roles:
            - detect
          roles:
            - record
    detect:
      enabled: false
    onvif:
      host: 192.168.10.75
      port: 8999  # tenvis quirk
      user: admin
      password: "admin"
Hope this is useful for anyone still having one of these around.
in my example config, I use admin:admin since that is the configuration reset default.
  • The admin username cannot be changed AFAICT.
  • The password can be updated in the Tenvisty app, and I have definitely changed mine from the password default value: admin.
