I installed HA via libvrt all goes well, I have access to the web interface, I can install the integrations.
when I want to install Terminal && SSH it does not launch at all, either from the sidebar or directly from the addon list.
It displays a frame with successively 220x56, connection closed, reconnected
Hi the error log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] cli: applying...
[fix-attrs.d] cli: exited 0.
[fix-attrs.d] profile: applying...
[fix-attrs.d] profile: exited 0.
[fix-attrs.d] ssh: applying...
[fix-attrs.d] ssh: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] apks.sh: executing...
[cont-init.d] apks.sh: exited 0.
[cont-init.d] keygen.sh: executing...
[12:16:58] INFO: Restoring host keys...
[cont-init.d] keygen.sh: exited 0.
[cont-init.d] profile.sh: executing...
[cont-init.d] profile.sh: exited 0.
[cont-init.d] ssh.sh: executing...
[cont-init.d] ssh.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[12:17:00] INFO: Starting Web Terminal...
[12:17:00] WARNING: SSH port is disabled. Prevent start of SSH server.
[2021/12/27 12:17:00:2873] N: ttyd 1.6.3-3b174da (libwebsockets 4.1.4-v4.1.4)
[2021/12/27 12:17:00:2875] N: tty configuration:
[2021/12/27 12:17:00:2875] N: start command: tmux -u new -A -s homeassistant bash -l
[2021/12/27 12:17:00:2875] N: close signal: SIGHUP (1)
[2021/12/27 12:17:00:2875] N: terminal type: xterm-256color
[2021/12/27 12:17:00:2875] N: LWS: 4.1.4-v4.1.4, loglevel 7
[2021/12/27 12:17:00:2875] N: NET CLI SRV H1 H2 WS IPV6-off
[2021/12/27 12:17:00:2899] N: /usr/lib/libwebsockets-evlib_uv.so
[2021/12/27 12:17:00:5130] N: Using foreign event loop...
[2021/12/27 12:17:00:5134] N: Listening on port: 8099
[2021/12/27 12:19:03:2836] N: HTTP / - 172.30.32.2
[2021/12/27 12:19:03:7883] N: HTTP /token - 172.30.32.2
[2021/12/27 12:19:04:4624] N: HTTP /token - 172.30.32.2
[2021/12/27 12:19:04:7471] N: HTTP /token - 172.30.32.2
[2021/12/27 12:19:05:0468] N: HTTP /token - 172.30.32.2
[2021/12/27 12:19:05:2316] N: HTTP /token - 172.30.32.2
[2021/12/27 12:19:05:4749] N: HTTP /token - 172.30.32.2
[2021/12/27 12:19:05:7266] N: HTTP /token - 172.30.32.2
[2021/12/27 12:19:06:0207] N: HTTP /token - 172.30.32.2
[2021/12/27 12:19:06:2061] N: HTTP /token - 172.30.32.2
[2021/12/27 12:19:06:4714] N: HTTP /token - 172.30.32.2
[2021/12/27 12:19:06:8232] N: HTTP /token - 172.30.32.2
[2021/12/27 12:19:07:0698] N: HTTP /token - 172.30.32.2
[2021/12/27 12:19:07:3888] N: HTTP /token - 172.30.32.2
with new update today work fine
