Terminal & SSH Addon Problem
Trying to use ‘ha authentication reset’ to change a user’s password on Terminal & SSH community addon. But it always gives this:
$ ha authentication reset --username "user" --password "newpassword"
ERRO[0000] Unexpected server response
this command is limited due to security reasons, and will only work on some locations.
For example, the Operating System terminal.
Since i am using hassio (Docker) i simply have no idea to ssh into docker homeassistant container. Is there a way to disable this limitation on SSH addon?
You change the password in the addon configuration:
I think he’s trying to change a Home Assistant user’s password, not the SSH / Terminal password.
Yeah reading it again you’re probably right.
Actually i am trying to change a family user’s Home Assistant User password since he forgot his password; these family members are not admin users btw. In the end i deleted the user from config-Users and recreated it with the same name so i can assign a new password.
But the HA Shell login as “From the operating terminal” problem still exists since i can only login from SSH addon…
I have to do the same.
How to change other user’s password?
I couldn’t handled it, so i deleted and recreated the same username…
