I’m new to Home Assistant and just getting set up and am trying to get the Terminal & SSH add-on to work. When I go to the terminal mode, the display is upside-down, making it very difficult to use. Here is a screen shot:
I’ve tried restarting the add-on and restarting the HA server with no luck. I am able to get it to display correctly after rebooting my Raspberry Pi, but when I try pasting code into the terminal, it goes upside down. I have to manually enter code, which is fine for short lines, but pretty useless if I need to copy and paste large blocks. Also, restarting the add-on after it appears right-side-up causes it to go upside-down again.
I am running HA on a Raspberry Pi with the boot pointing to a SSD (not using an SD card). The primary display is a SunFounder 10" touch screen operating in a Kiosk mode. I’m running the HA supervisor version on top of a Raspbian OS.
Any advice would be appreciated!
