Termostat brak poczenia WI FI esp8266 ESPhome z HA
The thing here is that after disconnecting the display olet everything works and connects to WI FI and to HA.
In older versions of ESPhome everything was ok.
type or paste code here
```esphome:
  platform: ESP8266
  board: d1_mini
  on_boot:
    then:
      - lambda: "id(oled_contrast).publish_state(0.4);"
      - switch.turn_off: dallas_power
      - delay: 25s
      - switch.turn_on: dallas_power
substitutions:
  room: Kitchen # Room Name
  entity_heater: input_boolean.tut_thermo_fire_lr
  entity_cooler: input_boolean.tut_thermo_cool_lr
  default_low: "20.0"
  default_hi: "28.0"
wifi:
  ssid: !secret wifi_ssid
logger:
  logs:
    climate: none
    sensor: none
    dallas.sensor: none
api:
ota:
i2c:
switch:
  - platform: gpio
    pin:
      number: GPIO03
    optimistic: true
  - platform: gpio
    pin: D0
    inverted: true
  - platform: gpio
    pin: D5
    inverted: true
    optimistic: true
binary_sensor:
  - platform: gpio
    pin:
      number: D4
      inverted: true
    on_press:
      then:
        - switch.toggle: heat_cool
    on_click:
      - min_length: 1000ms
        max_length: 20000ms
        then:
          - switch.toggle: brightness
dallas:
  pin: D3
  update_interval: 3s
climate:
  - platform: thermostat
    min_cooling_off_time: 0s
    min_cooling_run_time: 0s
    # min_fanning_off_time: 0s
    # min_fanning_run_time: 0s
    min_heating_off_time: 0s
    min_heating_run_time: 0s
    min_idle_time: 0s
    visual:
      min_temperature: 15 °C
      max_temperature: 30 °C
    name: "${room} Thermostat"
    sensor: internal_temperature
    default_target_temperature_low: ${default_low}
    default_target_temperature_high: ${default_hi}
    cool_action:
      - switch.turn_on: relay_cooler
      - lambda: id(cool).publish_state(true);
      - homeassistant.service:
          service: homeassistant.turn_on
            entity_id: ${entity_cooler}
    heat_action:
      - switch.turn_on: relay_heater
      - lambda: id(fire).publish_state(true);
            entity_id: ${entity_heater}
    idle_action:
      - switch.turn_off: relay_cooler
      - switch.turn_off: relay_heater
      - lambda: id(cool).publish_state(false);
      - lambda: id(fire).publish_state(false);
          service: homeassistant.turn_off
  - platform: dallas
    address: 0xDF26FFCD1D64FF28
  - platform: rotary_encoder
    pin_a:
      number: D6
      mode: INPUT_PULLUP
    pin_b:
      number: D7
      mode: INPUT_PULLUP
    on_clockwise:
      - if:
          condition:
            switch.is_on: brightness
          then:
            - sensor.template.publish:
                state: !lambda "return id(oled_contrast).state + 0.01;"
            - lambda: |-
                id(oled1).set_contrast( id(oled_contrast).state );
          else:
            - if:
                condition:
                  switch.is_on: heat_cool
                then:
                  - climate.control:
                      target_temperature_high: !lambda "return id(this_thermostat).target_temperature_high + 0.5;"
                else:
                  - climate.control:
                      target_temperature_low: !lambda "return id(this_thermostat).target_temperature_low + 0.5;"
    on_anticlockwise:
      then:
        - if:
            condition:
            then:
                  state: !lambda "return id(oled_contrast).state - 0.01;"
              - lambda: |-
                  id(oled1).set_contrast( id(oled_contrast).state);
            else:
              - if:
                  condition:
                  then:
                    - climate.control:
                        target_temperature_high: !lambda "return id(this_thermostat).target_temperature_high - 0.5;"
                  else:
                    - climate.control:
                        target_temperature_low: !lambda "return id(this_thermostat).target_temperature_low - 0.5;"
display:
  - platform: ssd1306_i2c
    update_interval: 0.5s
    contrast: 0.4
    model: "SH1106 128x64"
    rotation: 180
    address: 0x3C
    lambda: |-
      if (id(fire).state) {id(ani_fire).next_frame(); it.image(0, 0, id(ani_fire));}
      else if (id(cool).state) {id(ani_fan).next_frame(); it.image(0, 0, id(ani_fan));}
      else {it.image(0, 0, id(home_thermometer));}
      it.print(64, 0,  id(font1), TextAlign::TOP_CENTER, "${room}");
      it.printf(64, 4, id(font2), TextAlign::TOP_CENTER, " %.1f°", id(internal_temperature).state);
      it.printf(0, 64, id(font3), TextAlign::BASELINE_LEFT, "L:%.1f°", id(this_thermostat).target_temperature_low);
      it.printf(128, 64, id(font3), TextAlign::BASELINE_RIGHT, "H:%.1f°", id(this_thermostat).target_temperature_high);
      if (id(brightness).state) {it.image(56, 51, id(bulb));}
      else if (id(heat_cool).state) {it.image(56, 51, id(arrow_right));}
      else {it.image(56, 51, id(arrow_left));}
animation:
  - file: "_icons/thermostat/fan.gif"
  - file: "_icons/thermostat/fire.gif"
image:
  - file: "_icons/thermostat/home-thermometer.png"
  - file: "_icons/thermostat/arrow-left-circle-outline.png"
  - file: "_icons/thermostat/arrow-right-circle-outline.png"
  - file: "_icons/thermostat/lightbulb-on-outline.png"
font:
  - file: "_fonts/nasalization.ttf"
  - file: "_fonts/refsan.ttf"
> Blockquote
English only please.
Tip: @Grzegorz484, use a translation website to change your title & message to English and you will get more help for sure!
Yeah sorry for being a bit blunt, it is in fact the first rule How to help us help you - or How to ask a good question
Hi, change the i2c: part in your yaml to:
i2c:
  frequency: 800kHz
@Grzegorz484: also change the title to English, that will attract more users.
It works thanks a lot.
