Package would be ignored
Python recognizes ‘cryptography.hazmat.bindings._rust’ as an importable package,
but it is not listed in the packages
configuration of setuptools.
‘cryptography.hazmat.bindings._rust’ has been automatically added to the distribution only
because it may contain data files, but this behavior is likely to change
in future versions of setuptools (and therefore is considered deprecated).
Please make sure that ‘cryptography.hazmat.bindings._rust’ is included as a package by using
the packages
configuration field or the proper discovery methods
(for example by using find_namespace_packages(...)
/find_namespace:
instead of find_packages(...)
/find:
You can read more about “package discovery” and “data files” on setuptools
documentation page.
=============================DEBUG ASSISTANCE=============================
If you are seeing a compilation error please try the following steps to
successfully install cryptography:
- Upgrade to the latest pip and try again. This will fix errors for most
users. See: This page has moved - pip documentation v22.2.2
- Read Installation — Cryptography 39.0.0.dev1 documentation for specific
instructions for your platform.
- Check our frequently asked questions for more information:
https://cryptography.io/en/latest/faq/
- Ensure you have a recent Rust toolchain installed:
https://cryptography.io/en/latest/installation/#rust
Python: 3.10.7
platform: Linux-3.18.79-armv7l-with-libc
pip: n/a
setuptools: 65.4.1
setuptools_rust: 1.5.2
rustc: n/a
error: cargo rustc --lib --message-format=json-render-diagnostics --manifest-path src/rust/Cargo.toml --target armv7-linux-androideabi --release -v --features 'pyo3/extension-module pyo3/abi3-py36' -- --crate-type cdylib
failed with code 101
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for cryptography Failed to build cryptography
ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
