I have spent the last few days setting up a new bioactive terrarium and automating it for my son’s Leopard Gecko.
I first thought that a generic. thermostat in HA would be sufficient but discovered that the chosen heat source ( a deep heat projector) preferred dimming instead of an on-off function. I don’t know much about coding but was able to piece together the following auotmations.
My concern is that the automations do not have the intended effects of getting the terrarium to the desired temps and then maintaining it.
Any input would be much appreciated.
The first Automation turns the heat on full at sunrise
Can you elaborate on what you mean by the light prefers to be dimmed?
If the temperature sensor failed (or simply lost connection with Home Assistant), it would cease to report the terrarium’s temperature. That could negatively impact the Numeric State Trigger.
I would create an automation to monitor the health of the temperature sensor. For example, check if it’s state becomes unavailable and if it hasn’t reported a new value in more than 15 minutes.
According to their website
" As with all lamps, should be used with a thermostat. A dimming thermostat will provide accurate control of your thermogradient. You should check the temperature with a suitable quality non-contact laser thermometer. If used correctly this high quality, handmade heating lamp should provide you with years of stable heat provision. "
According to various other sites “correctly” means to reduce heat cycles
What kind of temperature sensor is sensor.terrarium_terrarium_hot_end_floor?
EDIT
I don’t know enough about the care of a gecko to determine if the automations you have created are sufficient, and reliable, to ensure its health. However, given that an animal’s life is involved, what I suggest is to assume the worst can happen and make contingencies. Plan for the temperature sensor and the light to fail; monitor them and report when they’re misbehaving (no temperature reported, light is on but no temperature increase is detected, etc).
- platform: dht
pin: GPIO26
model: dht22
temperature:
name: "Terrarium Hot End Temperature"
humidity:
name: "Terrarium Hot End Humidity"
update_interval: 60s
- platform: dht
pin: GPIO27
model: dht22
temperature:
name: "Terrarium Cool End Temperature"
humidity:
name: "Terrarium Cool End Humidity"
- platform: dallas
address: 0xd63ce1d458546228
name: "Terrarium Cool End Floor"
- platform: dallas
address: 0x903ce1d443d97b28
name: "Terrarium Hot End Floor"
The “Terrarium Hot End Floor” DS18B20 sits on the basking rock which is directly under the heating source.
I will be cycling this terrarium for the next week or so before introducing life.
Part of this cycling will be adjusting the total wattage/ distance of the heater so it is impossible to heat this unit above the tolerable temperature of the life housed in it and the ambient temp of the room the terrarium is in is above the minimum temp the life can tolerate.
You’re missing one very important aspect of this. You MUST have a dimming thermostat or dimming power regulator connected to a micro-controller (like an Arduino) for you to be able to actually adjust the amount of power going to the DHP. No amount of coding will substitute a dimming power supply since all you will be able to do is turn it on and off.
Spyder Robotics makes something called a HerpStat which can run pretty expensive depending on how many sensors or power connections you want to control. But, it does exactly what you’re wanting H.A. to do.
I’m actually in the process of building my own version of the HerpStat in a different way from them and so that it natively works with H.A.
Yes this has been working well for the last few month. Our Gecko is very happy these days.
I have the following two automations running. Paired with a dimmable zigbee plug keeps the temps perfect and the fixtures powered. No on and off.
the first automation increase the power output of the plug if the temp falls below 34 during the day.
Super interesting! Looks like exactly what I intend to do for our reptile (I’m not happy with the off the shelf controller)
Could you give me a hand and point me to the hardware you used for the dimmer and temperature probe?
Also have you made any changes/improvements since your post?
If you want to control temperature, one possibility is to use Shelly Dimmer.
You may have a look at my project Shelly-Terrariensteuerung. I am using German language for it, hope that’s fine. It runs without home assistant on Shelly, but you can control everything and see history etc. using HA.
