Tesla Powerwall "failed setup"
Hi - having trouble with setting up Tesla Powerwall core integration
Previously was set up and running well, ran updates to HA core and supervisor
Not sure if this was what caused the problem
Tried rolling back to a backup a couple of days ago but having the same problem with failed setup.
Deleted the integration and re-installed: Entered IP and password successfully
Now getting: “Failed setup: will retry, Check Logs”
Host log shows:
2024-12-06 20:52:55.146 homeassistant dockerd[597]: time="2024-12-06T20:52:55.144851161Z" level=error msg="[resolver] failed to query external DNS server" client-addr="udp:172.30.32.3:39625" dns-server="udp:192.168.1.1:53" error="read udp 172.30.32.3:39625->192.168.1.1:53: i/o timeout" question=";owner-api.teslamotors.com.\tIN\t A"
DNS log:
[INFO] 127.0.0.1:43536 - 32779 "A IN owner-api.teslamotors.com. udp 54 true 2048" - - 0 8.349804259s
[ERROR] plugin/errors: 2 owner-api.teslamotors.com. A: dial tcp 1.1.1.1:853: i/o timeout
[INFO] 127.0.0.1:52736 - 2913 "AAAA IN owner-api.teslamotors.com. udp 54 true 2048" - - 0 8.350679658s
[ERROR] plugin/errors: 2 owner-api.teslamotors.com. AAAA: dial tcp 1.1.1.1:853: i/o timeout
[INFO] 127.0.0.1:37156 - 40507 "AAAA IN owner-api.teslamotors.com. udp 54 true 2048" - - 0 5.003198365s
[ERROR] plugin/errors: 2 owner-api.teslamotors.com. AAAA: dial tcp 1.0.0.1:853: i/o timeout
[INFO] 127.0.0.1:45100 - 38550 "A IN owner-api.teslamotors.com. udp 54 true 2048" - - 0 5.004223187s
[INFO] 172.30.32.1:43616 - 61664 "A IN owner-api.teslamotors.com. udp 43 false 512" - - 0 12.005671121s
[ERROR] plugin/errors: 2 owner-api.teslamotors.com. A: read udp 127.0.0.1:39280->127.0.0.1:5553: i/o timeout
[INFO] 172.30.32.1:43616 - 62701 "AAAA IN owner-api.teslamotors.com. udp 43 false 512" - - 0 12.006009321s
[ERROR] plugin/errors: 2 owner-api.teslamotors.com. AAAA: read udp 127.0.0.1:42881->127.0.0.1:5553: i/o timeout
[INFO] 127.0.0.1:35947 - 59005 "AAAA IN owner-api.teslamotors.com. udp 54 true 2048" - - 0 5.004656457s
[INFO] 127.0.0.1:44876 - 5369 "A IN owner-api.teslamotors.com. udp 54 true 2048" - - 0 5.004056723s
[INFO] 127.0.0.1:59192 - 20411 "AAAA IN owner-api.teslamotors.com. udp 54 true 2048" - - 0 5.003844221s
[ERROR] plugin/errors: 2 owner-api.teslamotors.com. AAAA: context deadline exceeded
[INFO] 127.0.0.1:42881 - 31418 "AAAA IN owner-api.teslamotors.com. udp 54 true 2048" - - 0 6.005953867s
[INFO] 127.0.0.1:40404 - 7274 "AAAA IN auth.tesla.com. udp 43 true 2048" - - 0 5.003440422s
[ERROR] plugin/errors: 2 auth.tesla.com. AAAA: dial tcp 1.0.0.1:853: i/o timeout
[INFO] 127.0.0.1:33851 - 53628 "A IN auth.tesla.com. udp 43 true 2048" - - 0 5.004257022s
[ERROR] plugin/errors: 2 auth.tesla.com. A: dial tcp 1.1.1.1:853: i/o timeout
[INFO] 172.30.32.1:40732 - 6610 "AAAA IN auth.tesla.com. udp 32 false 512" - - 0 12.007601029s
[ERROR] plugin/errors: 2 auth.tesla.com. AAAA: read udp 127.0.0.1:39447->127.0.0.1:5553: i/o timeout
[INFO] 172.30.32.1:40732 - 5906 "A IN auth.tesla.com. udp 32 false 512" - - 0 12.008000449s
[ERROR] plugin/errors: 2 auth.tesla.com. A: read udp 127.0.0.1:40612->127.0.0.1:5553: i/o timeout
[INFO] 127.0.0.1:48203 - 57605 "AAAA IN owner-api.teslamotors.com. udp 54 true 2048" - - 0 7.8535996390000005s
[INFO] 127.0.0.1:37713 - 54554 "A IN owner-api.teslamotors.com. udp 54 true 2048" - - 0 7.854319519s
[ERROR] plugin/errors: 2 owner-api.teslamotors.com. A: dial tcp 1.0.0.1:853: i/o timeout
Not sure what this means or how to fix it
I can log in via browser to the UI of the gateway
Any ideas please?
Similar issue with Reolink integration also:
Happened at same time and same failed setup message
Worked well previously
Updated core to 2024.12.1
Now both apps seem to be working again…
