Tesla powerwall fails
Brand new HA. Powerwall 2, I’m able to connect via the web interface.
2024-02-12 21:51:06.195 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Home Energy Gateway for powerwall
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 444, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/powerwall/__init__.py", line 133, in async_setup_entry
    base_info = await _login_and_fetch_base_info(
  File "/usr/src/homeassistant/homeassistant/components/powerwall/__init__.py", line 219, in _login_and_fetch_base_info
    return await _call_base_info(power_wall, host)
  File "/usr/src/homeassistant/homeassistant/components/powerwall/__init__.py", line 241, in _call_base_info
    raise e.exceptions[0] from None
  File "/usr/local/lib/python3.12/site-packages/tesla_powerwall/powerwall.py", line 127, in get_batteries
    return [BatteryResponse.from_dict(battery) for battery in batteries]
  File "/usr/local/lib/python3.12/site-packages/tesla_powerwall/responses.py", line 305, in from_dict
    grid_state=GridState(src["pinv_grid_state"]),
  File "/usr/local/lib/python3.12/enum.py", line 744, in __call__
    return cls.__new__(cls, value)
  File "/usr/local/lib/python3.12/enum.py", line 1158, in __new__
    raise ve_exc
ValueError: '' is not a valid GridState
2024-02-12 22:07:03.881 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Home Energy Gateway for powerwall
    raise ve_exc
This likely indicates that one or more of your Powerwall batteries is offline or disabled. You may have some luck using the Netzero for Tesla mobile app to further diagnose your local setup.
There are two open issues on GitHub related to this:
