josephny
(Joseph)
June 24, 2023, 1:37pm
1
I would like to set up an automation to cycle the power on a relay based on whether a network device is connected on the local LAN.
But, I would prefer to use the device’s MAC address to eliminate any possible change in IP address causing failure in the future.
Can anyone help with this?
I imagine an NMAP-type scan based on MAC address.
Thank you!
SVD-NL
June 24, 2023, 1:51pm
2
You can use the NMAP tracker integration combined with device tracker integration
Then set your automations based on presence
Edit:
You can also consider using ping with hostname if that’s possible, that’ll also prevent issues with changing IP addresses, and is going to be more efficient.
Or simply setting a static for the device on your router
josephny
(Joseph)
June 24, 2023, 4:46pm
3
Thank you so much.
If ping would be more efficient, I can do that with either hostname or static ip.
josephny
(Joseph)
June 26, 2023, 11:43am
4
In case anyone is interested, this is the code I used to get this to work.
I’m sure it is primitive by the standards of the experts here, but it’s more than I could create a couple weeks ago:
alias: THR316-Attic State is off
description: ""
- platform: state
entity_id:
- binary_sensor.ping_thr316_shelly1
to: "off"
for:
hours: 0
minutes: 10
seconds: 0
condition:
- alias: Unable to ping THR316
condition: state
entity_id: binary_sensor.ping_thr316_shelly1
state: "off"
for:
hours: 0
minutes: 2
seconds: 0
- service: notify.notify
message: Ping lost to 125THR316-Attic
title: HA Notify
- service: notify.notifier_name
message: THR316 Attic Lost Connectivity
- service: notify.mobile_app_iphone
message: test notification
enabled: true
- service: switch.turn_off
data: {}
entity_id: switch.shelly_shsw_1_e8db84d6d456
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- service: switch.turn_on
data: {}
mode: single
