I am planning to move my HA system in the long term. But before I do that, I would like to test the cooling performance of the future HA system on a Raspi5 with NVMe drive.
Is there any integration or add-on that can be used to run as a kind of stress test?
found a solution myself using the terminal & ssh-add-on and this simple one-line command found here:
for i in $(seq $(getconf _NPROCESSORS_ONLN)); do yes > /dev/null & done
You can find the stress-test results at the bottom in a screenshot.
But first of all, a few words of explanation:
The reason for this test is that the Raspi 5 (especially with NVMe drive) is relatively new hardware for the HA. To make matters worse, in my case it is installed in a network rack.
I also mounted a third fan vertically on the side (4).
I hoped that these two modifications would allow me to cool the NVMe drive and also blow out the air congestion between the Raspi’s own fan and the NVMe hat (5).
And, what can I say: it turns out this way I really get a better idle and stress temp about 20°C below the mentioned test results:
