I am a software developer and just started using homeassistant. (I had used a selfmade solution before, that integrated with homekit, but now wanted to get rid of homekit as a automation hub and get all sensors in a central place, thus switched to Home Assistant).
I am writing some blueprints right now that should do quite some complex tasks (e.g. Automation of my light scenes based on presence, ambient light levels, state of other lights, time of day, events in the calendar, etc.).
From developing software, I am used to write the interface first, then write tests for the interface and then develop the core functionality until the tests are successful. I am missing that kind of functionality in Home Assistant.
What I would love to see is a e.g. commandline tool, that I can provide my blueprint, then feed some simulated sensors into its inputs and then run the test bench (which might e.g. be written using jest or whatever is the python equivalent).
One example would be:
describe("my-blueprint.yml", (blueprint) => {
it('triggers away scene if presence just changed to away', () => {
// given
const presence = new BinarySensor()
const awayScene = new Scene('away')
presence.set('on')
// UUT
blueprint.inputs({
presence_sensor: presence,
scene_away: awayScene
// when
presence.set('off')
// then
expect(awayScene).toBeTriggered()
// Or something like:
expect(blueprint).toHaveTriggered({service: 'scene.turn_on', entity_id: 'scene.away'})
is there already such a project or feature?
Would be awesome to have something like this. It might also provide syntax errors in the blueprints if something is wrong.
Alternatively it could be built into the blueprints itself, so that they have a “test” key wit the test suites and when you load a blueprint it runs the tests first to see if it is doing what it is supposed to. e.g.:
blueprint:
name: My Cool Blueprint
author: Tobisk
domain: automation
inputs:
- name: my_input
variables: ...
triggers: ...
conditions: ...
actions: ...
tests:
- name: My Test
input:
my_input: ...
given:
device1:
state: on
when:
device1:
state: off
then:
- action_contains:
- action: scene.turn_on
entity_id: scene.my_scene
data: ...
