Testers wanted - Netatmo integration
Hi Gerard,
Thanks for the great feedback.
Unfortunately the API does not provide any webhook events for that, neither officially documented nor did anyone report that to me (since I don’t have an outdoor camera).
The brightness of the light (not even the light itself) is officially documented. But if it can be set via the app it might also be possible via the (unofficial) API.
I notice an image delay of about 15 seconds which is not there in the Netatmo Security application. Does it just happen to me?
I have loaded the integration through HACS and the cameras are not working, this is the debug:
020-08-08 17:08:07 DEBUG (SyncWorker_1) [homeassistant.components.netatmo.climate] Invalid home None
2020-08-08 17:08:07 DEBUG (SyncWorker_3) [homeassistant.components.netatmo.sensor] weather station detected!
2020-08-08 17:08:07 DEBUG (SyncWorker_3) [homeassistant.components.netatmo.sensor] Adding module Study 70:ee:50:03:c7:14
2020-08-08 17:08:07 DEBUG (SyncWorker_3) [homeassistant.components.netatmo.sensor] Adding module Rain gauge 05:00:00:00:9b:82
2020-08-08 17:08:07 DEBUG (SyncWorker_3) [homeassistant.components.netatmo.sensor] Adding module Gym 03:00:00:03:29:84
2020-08-08 17:08:07 DEBUG (SyncWorker_3) [homeassistant.components.netatmo.sensor] Adding module Wind Gauge 06:00:00:01:2d:5a
2020-08-08 17:08:07 DEBUG (SyncWorker_3) [homeassistant.components.netatmo.sensor] Adding module Living Room 03:00:00:04:b2:70
2020-08-08 17:08:07 DEBUG (SyncWorker_3) [homeassistant.components.netatmo.sensor] Adding module Outdoor 02:00:00:27:76:a0
2020-08-08 17:08:07 DEBUG (SyncWorker_3) [homeassistant.components.netatmo.sensor] Adding module Master Bedroom 03:00:00:08:11:b2
2020-08-08 17:08:07 DEBUG (SyncWorker_3) [homeassistant.components.netatmo.sensor] No home coach entities found
2020-08-08 17:08:07 DEBUG (SyncWorker_7) [homeassistant.components.netatmo.camera] Setting up camera 70:ee:50:2d:25:96 Garage
2020-08-08 17:08:07 DEBUG (SyncWorker_7) [homeassistant.components.netatmo.camera] Setting up camera 70:ee:50:28:2b:36 Back Yard
Do you use HA cloud link or configuration.yaml?
I used the cloud link
That explains it. The cloud link does not yet support cameras.
right, now it works with config.yaml. Thanks!
Is there some issue with the login?
Since I updated to latest and rebooted HA, I get:
No camera and no sensor is working in HA.
But in debug log, I see webhook is working.
Interesting, haven’t seen that before. Might be a timing issue. Can you reproduce it or did another restart fix it?
Reproducible, restart doesn’t bring a solution.
Same log every restart.
2020-08-09 15:42:54 DEBUG (SyncWorker_4) [custom_components.netatmo.pyatmo.auth] The Netatmo API returned 403
2020-08-09 15:42:54 DEBUG (SyncWorker_4) [custom_components.netatmo.pyatmo.auth] Netato API error: b'{"error":{"code":3,"message":"Access token expired"}}'
2020-08-09 15:42:54 DEBUG (MainThread) [custom_components.netatmo.data_handler] 403 - Forbidden - Access token expired (3) when accessing 'https://api.netatmo.com/api/gethomecoachsdata'
Did this just happen after a normal restart?
Yes, normal restart.
I need to add the possibility to reauthenticate. I haven’t seen this in a long time.
Could I do something in between?
Only thing I can think of is remove and re-add the integration.
Please check my PM first.
A post was split to a new topic: Switching heat for Netatmo climate device is not reflected in UI
Was wondering what the latest status is on the custom component and the integration in HA?
I saw that the repo is archived. So now new version will be made available there?
It has been merged into 0.114 but for some reason it didn’t make it into the changelog.
That’s good to know! Then I can remove the custom component :grinning:
dev.netatmo.com down?`
I´m not able to login, since to days to unban the webhock…
There is no website appearing on different systems, browsers and internet connection.
someone experience the same?
