Testing variables (in a script) using `contains`
Hey all,
I know the following works (using == or in):
{% set scene = '1_hallway' %}
{{ scene == '1_hallway' }}
{{ scene in ['1_hallway','2_some_on'] }
However, I’d like to use contain (as below):
{{ scene contains '1' }}
However, this results in TemplateSyntaxError: expected token 'end of print statement', got 'contains):
I’ve also tried this (which results in unknown):
{{ states(scene,'contains','1') }}
Is using contains (or match, search) not possible with variables or am I missing a trick?
contains checks if an item exists within a list (or string; it needs to be iterable).
Example 1
{{ scene in ['1_hallway','2_some_on'] }}
{{ ['1_hallway','2_some_on'] | contains(scene) }}
Example 2
{{ scene | contains('1') }}
thanks - helpful as usual!
follow up: I was going to use a list, but, if so, I should always use your first example?
i.e. example 2 isn’t for lists?
edit: I should rephrase my question:
I’m looking for something like this (and I know this doesn’t work) where I can check to see if either ‘1’ or ‘2’ is in the variable.
{{ scene | contains('1'|'2') }}
{{ scene is search('1|2') }}
