I´m trying to enhance the integration of Tesvor M1 with Tuya and would like to add the battery status information into Home Assistant.
As you can see below, the integration brings even the cleaning area, but someone forgot to add the battery level to it:
Hi, Tesvor M1 conecta to Tuya very quickly. I’ve just reset it (long press in the start button) and it will connect to Tuya while searching .
But note that Tesvor M1 is different than the Tesvor x500. I have both devices at home and for some reason I can’t connect the x500 to Tuya but I can do it for M1.
I know how to connect it to tuya app. My question is how did you connect the tesvor in HA. If i try to scan the qr code after I add the security code, does not work…
@KosoTheOne I figured it out. You don’t use Tesvor app but you use Tuya app. This trick will do it.
Tip: do not try to use Smart Life app. ( despite it is the same owner as Tuya, the functionality is a bit different)
Thanks Adrian, this is correct.
I couldn’t connect the x500 model to Home Assistant, but only the M1 version (using Tuya App)
Were you able to connect?
