Hi any body manage to communicate with Tesy convector cn05 heater ? i try to call some API on post method on HTTP I received success but nothing happened any suggestions or guidance please !
Have you tried restful? RESTful - Home Assistant
NO because i dont know the link I try to spy the source code on web page but I don understand to much
TO find the link I try from image below .
If you have any suggestion i am open to try .
Many thx
I managed to find the correct way to put he post message, is finished with success but doesnβt do the command on of or set temperature β¦
What you are showing is not home assistant, it looks like postman or something.
You need to take what you have learned in postman and then use the rest integration to integrate it in HA.
If you canβt get postman to work, it is nothing to do with HA . Helpful people may help you, but you really need to ask Test (whoever they are)
I created an integration which allows you to connect this and possibly other similar connectors to HA:
Its asking me to put temperature_entity, what should i put there?
Sorry for the late reply. Since Tesy doesnβt provide the data from the built-in sensor that measures the temperature, you can provide your own room temperature sensor. You can also leave it empty and it will default to the target temperature.
