Hi All,
I have an issue that I can’t find the root cause of, hoping some will be able to point in the right direction.
I have Home Assistant running on a Pi4
- Core2024.3.0
- Supervisor2024.04.0
- Operating System12.0
- Frontend20240306.0
I’m running a Texecom Elite 64 V5.06.00 LS1 with the Com module over WiFi. I have the Texecom2MQTT add on installed (v1.2.3) and the alarm panel working with the UDL config.
I can see the panel, I can see a MQTT boot up and discover the 11 zones I have on the panel.
2024-04-08 18:42:43 - INFO: Starting texecom2mqtt v1.2.3 (Node v16.13.0)…
2024-04-08 18:42:43 - INFO: Connected to alarm, sleeping for 2 seconds…
2024-04-08 18:42:45 - INFO: Connection ready
2024-04-08 18:42:45 - INFO: Logging in to panel
2024-04-08 18:42:45 - INFO: Successfully logged in to panel
2024-04-08 18:42:45 - INFO: Connected to MQTT broker: x.x.x.x:1883 (retain: true, clean: true, client_id: texecom2mqtt, qos: 2)
2024-04-08 18:42:45 - INFO: Serial number: xxxxxxxx
2024-04-08 18:42:46 - INFO: Panel: Premier Elite 64 (V5.06.00LS1)
2024-04-08 18:42:46 - INFO: Fetched Area A: Entire House
2024-04-08 18:42:46 - INFO: Fetched Area B: Area B
2024-04-08 18:42:46 - INFO: Fetched Area C: Area C
2024-04-08 18:42:46 - INFO: Fetched Area D: Area D
2024-04-08 18:42:49 - INFO: Fetched Zone 10: Garage Door (Type: Guard; Areas: A)
2024-04-08 18:42:50 - INFO: Fetched Zone 11: Front Room Patio Door (Type: Guard; Areas: A)
2024-04-08 18:42:50 - INFO: Fetched Zone 12: Family Room Patio Door (Type: Guard; Areas: A)
2024-04-08 18:42:50 - INFO: Fetched Zone 13: Back Door (Type: Guard; Areas: A)
2024-04-08 18:42:50 - INFO: Fetched Zone 14: Family Room PIR (Type: Guard; Areas: A)
2024-04-08 18:42:51 - INFO: Fetched Zone 15: Garage PIR (Type: Guard; Areas: A)
2024-04-08 18:42:51 - INFO: Fetched Zone 16: Landing PIR (Type: Guard; Areas: A)
2024-04-08 18:42:51 - INFO: Fetched Zone 17: Front Door (Type: Entry/Exit 1; Areas: A)
2024-04-08 18:42:52 - INFO: Fetched Zone 18: Hall PIR (Type: Entry/Exit 1; Areas: A)
2024-04-08 18:42:52 - INFO: Fetched Zone 19: Master Bedroom Patio Door (Type: Guard; Areas: A)
2024-04-08 18:42:52 - INFO: Fetched Zone 20: Front Sounder (Type: Custom; Areas: A)
2024-04-08 18:42:53 - INFO: Fetched Zone 21: Garage Sounder (Type: Custom; Areas: A)
2024-04-08 18:43:06 - INFO: Updating all zone states…
2024-04-08 18:43:07 - INFO: Updating all area states…
2024-04-08 18:43:07 - INFO: Application ready
I can set the alarm and see the state change of 6 of the binary sensors. My issue is that I can only see 6 of the 11 sensors! When I go into entities, I only see the six of them. Although they are being discovered during startup the binary sensors are not being created as entities.
Any guidance or suggestions welcomed!
