Is it possible to use these two together? For example I would like so show sensors that are tripped and if the washing machine is running or if its trash day, and have them broke out into catagories using the text-divider-row.
Why not use a vertical stack?
That keeps them in the same column but not in the same card.
Try this then:
you can have an additional markdown card with a divider then
ah thank you, that should do it!
