Text helper not filled with name of the sensor
When activated my alarm I fill in a helper (text) with the text “Sensor onbepaald” :
      - service: input_text.set_value
          value: Sensor onbepaald
          entity_id: input_text.text_sensor_die_alarm_activeert
When a sensor detects motion I do 2 things : setting a helper (boolean) on ‘on’ and filling the text helper with the name (and date/hour) of the sensor :
      value: >-
        Sensor gang op {{ as_timestamp( now() | as_local, 0)|
        timestamp_custom('%d/%-m/%-Y ''om'' %H:%M:%S') }}
    data: {}
      entity_id: input_boolean.toggle_alarm_activeren
An automatisation based on that boolean gives the alarm :
  - platform: state
    to: 'on'
condition: []
  - service: notify.notification_devices
      message: >-
        INTRUDER ALERT! ({{ states('input_text.text_sensor_die_alarm_activeert')
        actions:
          - action: URI
            title: Camera's
            uri: /my-home/camera
          - action: DISABLE_ALARM_ONCE
            title: Vals Alarm ?
            title: Alarm uit
Now, I get the alarm on my phone but the helper input_text.text_sensor_die_alarm_activeert is still on ‘Sensor onbepaald’…so I don’t know which sensor is causing the alarm.
What am I missing ?
change this template to
    Sensor gang op {{ now().strftime("%d/%-m/%-Y om %H:%M:%S") }}
Both versions work in the developer tools :
But the problem seems indeed this date/time format. When I just put simple text, then it shows up.
Your method doesn’t work because you have 3 strings in a row, it will result in errors. What I posted is a single format and it should work.
I did this :
      value: Sensor gang op {{ now().strftime("%d/%-m/%-Y om %H:%M:%S") }}
In that case the textfield isn’t filled in at all.
With this it is filled (without date/time of course) :
Now I was wondering if it is posible to use templates… ?
because you have to use multiline notation or wrap the template in quotes. Seeing that you have quotes in your template, you should have just done what you did before.
      value: >-
Don’t shoot me, I found the problem : the length of my text helper was only 20 :pleading_face:
Thanks for helping me out of this !
