Text to Speech TTS - Reading Attribute Values NOT WORKING
I’m trying to create a script that will make my Google Home Speaker tell me what temperature my heater is currently set to. I’d not need to do this if ecobee thermostat were elegantly integrated with Google Assistant and also useful as the thermostat is in the hallway and i can’t see it from my living area.
My problem: the TTS command actually reads out loud the text “states.climate.home.attributes.temperature” rather than reading out the attribute value
  ecobee_temp_script:
    sequence:
      - alias: Google TTS
        service: tts.google_say
        entity_id: media_player.kitchen_home
          message: 'The Ecobee is currently set to {{ states.climate.home.attributes.temperature }} degrees'
      - alias: Send Email
        service: notify.Email_Notification
          title: 'The Ecobee is currently set to {{ states.climate.home.attributes.temperature }} degrees'
I know I’ve entered it correctly as the “send email” command shown displays the text correctly, but the TTS component does not.
Any ideas on how i can covert the attribute value to text for use with the TTS component?
OK I’ve found the solution here: https://home-assistant.io/components/tts/
Basically I’ve to use “data_template:” instead of “data”. The code looks like the below:
  ecobee_temp_script:
    sequence:
      - alias: Google TTS
        data_template:
