Just a few days ago, Amazon released “Polly”, which is a decent sounding text to speech platform, and very cheap (for those of you not familiar with AWS, it is a collection of computing services that you only pay for exactly what you use). After a day of fiddling and tinkering, I have put together a Lambda (which allows a person to run an application without a server and only pay for the resources used) application which does the following:
- Receives a request via AWS API Gateway
- Reads the text to be spoken
- Determines if the text has already been converted to audio
- If so:
4.1. Locates the audio on the S3 bucket you specify, where it would have saved it already
4.2. Uses the HASS API to play the audio on a media player you specify - If not:
5.1. Has Polly speak the voice, and saves it to an S3 Bucket
5.2 Uses the HASS API to play the audio on a media player you specify
Here’s the code. Note, it includes the aws-sdk node.js module, because the pre-installed one in Lambda is not updated to have the Polly API. In the future, this will not have to be included, and the stock one can be used - saving some utilization time.
As for hass configs:
notify:
- name: "AWS Polly"
platform: command_line
command: "xargs --replace=@ curl -X GET -H 'Content-Type: application/json' -H 'x-api-key: YOUR_API_KEY' -G https://YOUR_API_ENDPOINT.us-east-1.amazonaws.com/prod --data-urlencode 'text=@'"
automation:
- alias: 'Welcome home'
hide_entity: true
platform: state
entity_id: group.all_devices
state: 'home'
service: notify.AWS_Polly
message: "Hi, this is your house speaking. Welcome home!"
I know the details are sparse so far, but I’ll work on putting together something with a little more documentation. I use this to have notifications spoken over my Chromecast Audio devices, and my Google Home. I have them all in a “home group”, so all speakers play the notifications. From the trigger to the audio starting is about 4 seconds.
It is worth noting I also have a site-to-site VPN between my house and AWS, and have the Lambda code running in my VPC network context - so this all stays “internal” to the house, without having to expose the HASS API publicly.
Finally, if you don’t want your whole-house music or the movie you’re watching to stop because of a notification, you can always add in some conditions to the automation rule:
condition:
condition: or
conditions:
- condition: state
entity_id: media_player.home_group
state: 'idle'
- condition: state
state: 'off'
