thermiek
(thermiek)
August 14, 2024, 7:55pm
1
hello ,
Hello, I have imported an entity in ESPHome and want to create an if statement to log different messages based on the entity’s value (“on” or “off”). I’ll be using the log as a test environment.
i tried many hours , lambdas , if then , google , chat gpt , but nothing worked
are there examples how to do this , so i can use it to learn and adapt it to my goal ?
text_sensor:
- platform: homeassistant
entity_id: binary_sensor.poortfdc
internal: False
on_value:
then:
- logger.log: "recieve ON"
else :
logger.log : "recieved off"
Import it as a binary_sensor instead of a text_sensor.
binary_sensor:
internal: true
on_press:
then:
on_release:
then:
- logger.log : "recieved off"
Btw. you should set sensors imported from HA as internal: true
, to avoid exporting them back to Home Assistant.
thermiek
(thermiek)
August 14, 2024, 8:20pm
3
been there done that to , then i got error : can’t convert ‘off’ to binary state
How did you create the binary_sensor in HA?
thermiek
(thermiek)
August 14, 2024, 8:47pm
5
the original entity in HA is via mqtt
but i dont want to spend processorpower and programmemory to set up a mqtt in my esp32
This works for me.
Home Assistant:
template:
- binary_sensor:
- name: "Is Night"
unique_id: is_night
state: >-
{% if now().hour <= 6 %}
{{ on }}
{% else %}
{{ off }}
{% endif %}
ESPHome:
binary_sensor:
entity_id: binary_sensor.is_night
If you can’t get it to work importing it as a binary_sensor, you could use a text_sensor, like this:
text_sensor:
internal: true
on_value:
- if:
condition:
text_sensor.state:
state: 'on'
then:
- logger.log: "recieved on"
else:
- logger.log: "recieved off"
thermiek
(thermiek)
August 14, 2024, 9:08pm
7
hello ,
i had it almost correct in my many hours of testing of code in the esp
i lost many time , and even google had no examples how to do this
i had a wrong condition :
condition:
state: 'on'
`text_sensor:
internal: true
on_value:
if:
condition:
text_sensor.state:
state: ‘on’
then:
- logger.log: “recieved on”
else:
- logger.log: “recieved off”`
thx , good night
Sounds like you spent hours trying and looking everywhere except going to the official esphome documentation where there are examples for exactly what you were trying to do…
You should always make this your first stop in the future, FYI.
