Thank's Connect and Home Assistant
Hello. I have several devices (power strips, bulbs, sockets) from the Thank’s brand that I control using the Thank’s connect app and Google Home. Unfortunately this equipment is not compatible with Home Assistant. Would it be possible to make it compatible? This would help me a lot and would save me from having to replace all my equipment. I think I’m not the only one in this case. Thank you very much
Hi
Did you search if they have an API or equivalent ? If they don’t have, integration is probably not possible at all !
It’s better to select products depending if they can be controlled or not than to think about it after having bought them :smiley:
Vincèn
Weird unknown brands are usually Tuya based. Try adding them t othe smartlife app and if they will go there, there is a HA Core Tuya integration and more can be found in GitHub via the HACS loader integration.
Blockquote Did you search if they have an API or equivalent ? If they don’t have, integration is probably not possible at all !
Yes and I didn’t find anything
Blockquote It’s better to select products depending if they can be controlled or not than to think about it after having bought them :smiley:
I agree, but when I bought them I didn’t think I would switch to HA
Blockquote Weird unknown brands are usually Tuya based. Try adding them t othe smartlife app and if they will go there, there is a HA Core Tuya integration and more can be found in GitHub via the HACS loader integration.
I tried but unfortunately my devices are not Smart Life compatible. Pairing does not work. I still managed to put them on Tuya (I don’t really know how). I can control them with it (still missing some features) but impossible to integrate them with local tuya and tuya cloud
