Good afternoon! I bought a server home assistant. The web used to open. the interface is at 192.168.1.141, and now it’s reaching armbian and I don’t know what to do next and I don’t understand why this happened either. I’m asking for your help. Has anyone ever had such a situation?
If I created the wrong theme, can you tell me where to create it, or maybe there is already such a theme?
Armbian is not a supported platform, so I think you are on your own. I see an error in your screenshot about a device not being found. That may be relevant.
I do not see you use the port Home Assistant usually is on. Did you forget to specify it? Home Assistant usually does not run on the standard http port.
He worked for me and I went to the address http://192.168.1.141 but I saw that it didn’t open, so I decided to see why and noticed that it was hanging in this state. What can I do to start the process further? I will be very grateful for your help!
HA has never been on port 80 unless you did something to set it there. Try http://192.168.1.141:8123/
Yes, that’s why the address. I just didn’t finish writing :8123. it used to load completely, but here it’s like I’m in some other section.
I already had the web interface installed, I connected several sensors and I got this error, which I showed above in the picture. Can I select the Clean Up Home Assistant command with the data folder? Is everything going back to normal for me? If it is possible to reset to factory settings, then it would be great, if this is possible, which team will help me do it. I’m worried that I might choose a bad team and there will be even more mistakes.
Since Armbian is not supported by Home Assistant, your best bet is the Armbian forum:
