Can you give the termux codes for the latest android installation? I always got errors with what I found on the internet. Please help me.
Don’t run Home Assistant on Android.
I have seen on the internet before that it can be installed via Termux.
Yes, it can, but just because you can doesn’t mean you should.
- It’s not supported, if stuff breaks/fails to work you’re largely on your own
- Phones are shitty servers
Just use a second hand PC, buy something new, or run it on hardware you already own.
I installed it on my computer, connected to the main server, installed the coolkit plugin for my sonoff devices, some but not all of my devices arrived, but I cannot give proper commands to the incoming devices ((This entity (" switch.1****e3952 ") does not have a unique ID, so the settings are set by the user It cannot be managed from the interface. See the documentation for more details.))) I get the error.
I’m new and I don’t have much knowledge. I would appreciate it if you could help me with home assistant.
That’s not an error, that’s an informational message. Read the FAQ entry
To control your switch
use the services.
