RenFle
(Rene)
December 20, 2023, 6:34am
1
Hi
i have an Aquara sensor on a window which shows me whether the window is open or closed.
now i would also like to show the status on a display at the front door.
that does not work.
the other indicators such as temperature and power consumption all work and update automatically.
binary_sensor:
- platform: homeassistant
entity_id: binary_sensor.fenster_schlafzimmer_offnet
if (id(schlafzimmerfenster)) {
it.printf(160,120, id(roboto30),TextAlign::CENTER, "offen");
else {
it.printf(160,120, id(roboto30),TextAlign::CENTER, "zu");
it.printf(160,120, id(roboto30),TextAlign::CENTER, "Window is %s", id(schlafzimmerfenster) ? "Open" : "Closed");
it makes no difference whether i write “id(schlafzimmerfenster)” or “id(schlafzimmerfenster).state”.
the change arrives in ESPhome.
[D][homeassistant.binary_sensor:026]: 'binary_sensor.fenster_schlafzimmer_offnet': Got state ON
[D][binary_sensor:036]: 'schlafzimmerfenster': Sending state ON
[D][homeassistant.binary_sensor:026]: 'binary_sensor.fenster_schlafzimmer_offnet': Got state OFF
[D][binary_sensor:036]: 'schlafzimmerfenster': Sending state OFF
unfortunately i have little knowledge of programming.
what am i overlooking here?
I can’t see anything obvious. I’d be debugging with the .state
in place rather than absent.
You could try adding in some logger messages to try to catch where it is going wrong (i.e at the if or the printf level).
if (id(schlafzimmerfenster).state) {
ESP_LOGD("custom", "Test 1");
it.printf(160, 120, id(roboto30),TextAlign::CENTER, "offen");
else {
ESP_LOGD("custom", "Test 2");
it.printf(160, 120, id(roboto30),TextAlign::CENTER, "zu");
zoogara
(Daryl)
December 20, 2023, 7:48am
3
If you don’t use .state
- you are referring to the whole sensor object, rather than it’s value.
In other words - you need to add .state
to the sensor id.
RenFle
(Rene)
December 20, 2023, 8:33am
4
but with “.state” it does not work either.
zoogara
(Daryl)
December 20, 2023, 9:37am
5
What does it actually print? Anything? Maybe post the rest of the yaml so we can see that code in the context of the whole display code?
Also give as an example of the expected out versus what you see on the display?
The logs showing the binary sensor updating and your custom log output would be good too.
RenFle
(Rene)
December 20, 2023, 10:13am
6
with “it.print” instead of “it.printf” it works
maybe because i had not specified any formatting for printf?
zoogara
(Daryl)
December 20, 2023, 10:16am
7
Yep - that would be it. Don’t worry I think many have been caught doing that - including me.
RenFle
(Rene)
December 20, 2023, 11:13am
8
this works
static bool show = false;
it.print(160,120,id(roboto40),id(my_red), TextAlign::CENTER_RIGHT,"Fenster:");
if (show) {
it.print(318, 120, id(roboto40), id(my_red), TextAlign::CENTER_RIGHT, "offen");
show = !show;
the text only appears when the window is open and “Offen” (OPEN) additionally blinks
“show” is only for blinking
The tip from @Mahko_Mahko with ESP_LOGD helped a lot.
