The ceiling fan that pushed me too far
This project started from with this thread explaining how you can use a Sonoff RF controller to integrate a ceiling fan with HA.
Well, after many days and hours of trying to get this working I eventually discovered I had the 303Mhz version of the remote and therefore incompatible with the 433Mhz controller… This became personal.
I ended up using an ESP8266, an 8 bank relay, and buying a 2nd remote control. From there I soldered 8 wires from each button and connected each, along with a ground bus, to the relay bank. I added the ESP8266 via ESPHome to HA and mapped each relay to a button. When a button is pressed this fires an automation to turn on a virtual switch to let me know the fan or light has been turned on in my HA dashboard. I plan to use a scene controller on the wall so this is the only way the light can be controlled so this doesn’t get out of sync.
It was a long way to go, but it works!
Stupid fan…
![68926764415__472B652E-148E-4AEC-AA53-4C572ED4F135|375x500]
Hi @catboxer i would like to ask you few things about this. Im totally interested on this.
Could be possible to chat? Thanks in advance!!!
Sure send PM if needed
Could you let me know how can I open the case
Pry it apart
