Hi there,
Today I have updated HA. Everything went ok but I keep getting this message in the logs:
2021-07-07 22:17:35 WARNING (MainThread) [homeassistant.components.shelly] The config entry configuration.yaml probably comes from a custom integration, please remove it if you want to use core Shelly integration
So I removed the shelly directory under custom_components and removed the shelly: settings in configuration.yaml. Restarted the core but the message keeps coming back.
Any idea’s what’s next to check?
For those like me which find this post from Google, I find a “solution” : you have to delete the entry
"entry_id": "[entry_id]",
"version": 1,
"domain": "shelly",
"title": "configuration.yaml",
"data": {},
"options": {},
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "import",
"unique_id": null,
"disabled_by": null
from file \config\.storage\core.config_entries
Restart home assistant and the error has disapeared ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
Maybe a bug somewhere, I think this entry should be deleted when we remove it from configuration.yaml
