The device and Home assistant network communication protocol?
I want to know the device and Home assistant network communication protocol ?
is must using request protocol HTTP ? or MQTT ? or must RESTful format ? or JSON Data ? can I use UTF8 data?
I suggest you start by reading the documentation.
Or just google it…
Thank you for your assistant
is must using HTTP ?
No - I gave you the link for MQTT and HA - how is that HTTP?
Indeed if you want to write your own integration for a device you can use any protocol you like. Including Bluetooth.
Actually, we are an all-in-one sensor device manufacturer. Currently, each sensor data uses a simple UTH8 data format and is uploaded to the WU website via WiFi router using HTTP. I would like to know if the HA API supports device data using HTTP or MQTT or UTH8 data format?thanks
Ok if you’re a manufacturer looking for advice then reach out to the developers on Discord -
You can also try contacting Nabu-Casa:
[email protected]
