The Easiest Method to Enable LAN/Developer Mode on Xiaomi Bulb
I’ve created a handy tool for managing Mi Home gadgets.
Here’s what it does in its first version:
  • Displays device info such as token, ip, and did.
  • Enables LAN mode for bulbs with a single click.
  • Executes commands effortlessly
Feel free to suggest new features! Let’s work together to make managing Mi Home gadgets even better.
The first candidate for the next enhancement is executing commands directly from plain input. For example, for LAN mode, it could be: "set_ps", ["cfg_lan_ctrl", "1"]. Let me know if this feature is needed or if you have any other ideas!
thanks a lot ! That worked perfectly! <3
Version 1.1.0 is available!
Execute commands with ease and simplicity.
Excellent! Finally I can do it easily from my Macbook :slight_smile: Thank you!
Hi, I can connect to the light and see the LAN mode is set to off, but if I try set it to on it just turns back off immediately. My light is identified as a yeelink.light.ceil43.
I’ve also tried to do this with the miiocli Linux tool but that also errors when trying to set the LAN mode / developer mode to on even though I can send commands to the light from it.
Do you think the manufacturer has permanently disabled the ability to use this setting? If so I’ll not be happy as this was an expensive light that looked like it would be HA compatible when I bought it.
Cheers.
Hi
I’ve installed the tool on my Windows laptop and it says “Login step 2 failed: No ‘ssecurity’ in response” uplon login attempt.
I’m connected on the German server and I confirm I can log in with my smartphone and the native Yeelight app.
Any idea ?
thanks !
This was fixed in v1.3.0. Could you please upgrade and confirm it’s working for you?
Hi
I installed your app, followed the instructions, I tried a few servers, but no matter what server I try, I get:
2FA failed: ‘identity_session’ cookie not found in the response
Am I doing something wrong?
Thanks.
Thank you for putting this together, I could enable LAN mode for only 1 of the 4 Yeelight devices I have using the Yeelight classic app, using this I had no issues enabling LAN mode for all 4 (German server)!
When I tried to log in, I received the following message:
Login failed
2FA Flow: Failed to send 2FA code. Response: &&&START&&&{“code”:70022,“desc”:“发送验证码失败”,“tips”:“Sent too many codes. Try again tomorrow.”,“title”:“”,“action”:“”}
There is a limit of 2FA requests per day. Try again tomorrow.
Hi, I have the same problem with this light. Did you find any solution? I was able to add the light to Home assistant with Xiaomi Miot integration (GitHub - al-one/hass-xiaomi-miot: Automatic integrate all Xiaomi devices to HomeAssistant via miot-spec, support Wi-Fi, BLE, ZigBee devices. 小米米家智能家居设备接入Hass集成) but still would like to enable the LAN mode and use this light with the yeelight app, as well as Hyperion, if possible.
Hey! Amazing app, worked good for me, just later I was logged out and had to log in again and it gives me endless captchas that won’t resolve for some reason. Did anything change maybe on Xiaomi’s side? Thanks for all! Kai
Oh I figured it out, my VPN was on…
I have a Yeelight Arwen D600 ceiling light, but unfortunately I can’t send the command to enable LAN mode. Has anyone managed to do this with this particular model, or does anyone have any ideas?
Whenever I try to send the command, I get an “unknown parameter” error.
I would be very grateful for any help or suggestions.
Thank you!
