ec4_remaining_time:
unique_id: ec4_remaining_time
friendly_name: "Remaining Time"
value_template: |-
{% set x = states.sensor.citroen_ec4.attributes["energy"][0]["charging"]["remaining_time"] %}
{% if x not in ['None', 'unknown', 'unavailable'] %}
{{ (x|as_timedelta).total_seconds() }}
{% else %}
{{x}}
{% endif %}
availability: {{ states.sensor.citroen_ec4.attributes["energy"][0]["charging"]["remaining_time"] | as_timedelta is not none }}
device_class: duration
unit_of_measurement: s
Is that a template sensor? That doesnât look like a rest sensor. Anyways, when you put that into the UI, the UI should translate it to HH:MM:SS. Try refreshing the page when viewing the entity in the entities card.
Well, youâre right, there is one rest sensor containing many aspects, which are then split out via various template sensors.
Please find an excerpt below, I replaced the real VIN by <<VIN>>
# Citroen ec4
- platform: rest
unique_id: citroen_ec4
resource: http://172.30.32.1:5000/get_vehicleinfo/<<VIN>>?from_cache=1
scan_interval: 60
timeout: 30
value_template: "OK"
json_attributes:
- energy
- timed_odometer
- battery
sensors:
ec4_battery_voltage:
unique_id: ec4_battery_voltage
friendly_name: "Battery Voltage"
unit_of_measurement: "V"
device_class: voltage
value_template: '{{ states.sensor.citroen_ec4.attributes["battery"]["voltage"] * 4 }}'
ec4_battery_level:
unique_id: ec4_battery_level
friendly_name: "Battery"
unit_of_measurement: "%"
device_class: battery
value_template: '{{ states.sensor.citroen_ec4.attributes["energy"][0]["level"] | round(0) }}'
ec4_charging_status:
unique_id: ec4_charging_status
friendly_name: "Charging Status"
value_template: '{{ states.sensor.citroen_ec4.attributes["energy"][0]["charging"]["status"] }}'
ec4_remaining_time:
value_template: |-
{% else %}
{{x}}
{% endif %}
Is there a reason you arenât using the rest integration to do all of this?
rest:
- resource: http://172.30.32.1:5000/get_vehicleinfo/<<VIN>>?from_cache=1
scan_interval: 60
timeout: 30
- unique_id: ec4_battery_voltage
name: EC4 Battery Voltage
unit_of_measurement: V
value_template: '{{ value_json.battery.voltage * 4 }}'
- unique_id: ec4_battery_level
name: EC4 Battery Level
unit_of_measurement: %
value_template: '{{ value_json.energy[0].level | round(0) }}'
- unique_id: ec4_charging_status
name: EC4 Charging Status
value_template: '{{ value_json.energy[0].charging.status }}'
- unique_id: ec4_remaining_time
name: EC4 Remaining Time
value_template: '{{ (value_json.energy[0].charging.remaining_time | as_timedelta).total_seconds() }}'
availability: '{{ value_json.energy[0].charging.remaining_time | as_timedelta is not none }}'
Secondly, the template you are using:
will return an invalid state for duration sensors. Making it not work, you cannot use that template. If you really want to stay with your current rest/template entity method, your value_template should be:
{{ (states.sensor.citroen_ec4.attributes["energy"][0]["charging"] | as_timedelta).total_seconds() }}
Thanks a lot.
and no, there is no reason for staying with my former approach. Will replace as youâve suggested and report the result here.
EDIT
tried your proposal, and get an error message when verifiying the yaml:
Invalid config for 'rest' from integration 'sensor' at sensors.yaml, line 129: 'sensor' is an invalid option for 'sensor.rest', check: sensor
it does not go in your sensor.yaml file. It goes in configuration.yaml. Itâs a separate integration from sensor
Now I remember why I was using template sensors. because I could change the icon of the template sensor, even in a dynamic manner depending on the value of the sensor.
For example
ec4_charging_plugged:
unique_id: ec4_charging_plugged
friendly_name: "Charging Plugged"
value_template: '{{ states.sensor.citroen_ec4.attributes["energy"][0]["charging"]["plugged"] }}'
icon_template: >-
mdi:power-plug{{ iif(is_state('switch.ec4_charging_plugged', 'True'),'', '-off') }}-outline
till now I couldnât figure out how to do that with rest sensors.
How does this one get the attribute remaining_time
You can just make that a binary sensor instead though with a device class.
I have no idea, you havenât shared the data from the rest end point.
