I created two buttons for testing.
If button A3 is pressed, playback is normal, and the ESP32S3 will not restart.
a3 media_url: ‘http://192.168.1.1:8080/static/music.mp3’
If you press button A4, the ESP32S3 will restart.
a4 media_url: ‘http://m10.music.126.net/20251106145338/61c9045ca5ef9d5d9177f15d5c162fd4/ymusic/48d9/4013/934e/cb8eb10c6141e33ab5e45033c10c10f2.mp3’
(The music link worked when I tested it, but it’s probably inaccessible now.)
Does anyone know what happened?
esphome:
friendly_name: a02
platformio_options:
board_build.flash_mode: dio
esp32:
board: esp32-s3-devkitc-1
variant: esp32s3
flash_size: 16MB
cpu_frequency: 240MHZ
framework:
type: esp-idf
version: recommended
# sdkconfig_options:
# CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
# CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
# CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
# CONFIG_ESP32S3_INSTRUCTION_CACHE_32KB: "y"
# CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST: "y"
# CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY: "y"
# CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC: "y"
# CONFIG_MBEDTLS_SSL_PROTO_TLS1_3: "y" # TLS1.3 support isn't enabled by default in IDF 5.1.5
logger:
# level: DEBUG
# level: VERBOSE
# level: VERY_VERBOSE
psram:
mode: octal
speed: 80MHz
captive_portal:
http_request:
globals:
- id: now_url
type: std::string
restore_value: no
debug:
update_interval: 10s
- platform: uptime
- platform: debug
free:
block:
name: "Heap Max Block"
loop_time:
psram:
cpu_frequency:
name: "CPU Frequency"
button:
- platform: factory_reset
on_press:
then:
- media_player.play_media:
media_url: 'http://192.168.1.1:8080/static/music.mp3'
on_press:
then:
media_url: 'http://m10.music.126.net/20251106145338/61c9045ca5ef9d5d9177f15d5c162fd4/ymusic/48d9/4013/934e/cb8eb10c6141e33ab5e45033c10c10f2.mp3'
i2s_audio:
- id: i2s_audio_bus
# i2s_output data pin is gpio7
i2s_lrclk_pin:
number: GPIO16
i2s_bclk_pin:
number: GPIO15
- id: i2s_audio_mic
# data line is GPIO6
i2s_lrclk_pin:
number: GPIO4
i2s_bclk_pin:
number: GPIO5
speaker:
- platform: i2s_audio
i2s_dout_pin: GPIO7
i2s_audio_id: i2s_audio_bus
dac_type: external
sample_rate: 48000
bits_per_sample: 32bit
buffer_duration: 1000ms
- platform: mixer
# task_stack_in_psram: true
output_speaker: echo_speaker
source_speakers:
- id: announcement_spk_mixer_input
# timeout: 500ms
# bits_per_sample: 16
# num_channels: 1
# sample_rate: 48000
- id: media_spk_mixer_input
# timeout: 500ms
# num_channels: 1
- platform: resampler
output_speaker: media_spk_mixer_input
# task_stack_in_psram: True
# num_channels: 1
output_speaker: announcement_spk_mixer_input
# task_stack_in_psram: false
# num_channels: 1
media_player:
- platform: speaker
announcement_pipeline:
# format: WAV
# codec_support_enabled: false
# buffer_size: 2000000
volume_min: 0.4
volume_max: 0.8
media_pipeline:
speaker: media_spk_resampling_input
# format: MP3
# num_channels: 1
This is information from esphome.
[12:44:46.113][D][button:023]: 'a3' Pressed.
[12:44:46.113][D][media_player:083]: 'a02' - Setting
[12:44:46.115][D][media_player:090]: Media URL: http://m801.music.126.net/20251106210840/993351aebcc226409ab8f9ae77c69311/jdymusic/obj/wo3DlMOGwrbDjj7DisKw/19529190250/c6df/fd20/58d2/75e9bdd3f516bf7609f8884ba3108aae.mp3
[12:44:46.118][D][media_player:096]: Announcement: no
[12:44:46.123][D][speaker_media_player:406]: State changed to PLAYING
[12:44:46.287][D][speaker_media_player.pipeline:114]: Reading MP3 file type
[12:44:46.302][D][ring_buffer:034][med_read]: Created ring buffer with size 1000000
[12:44:46.367][D][speaker_media_player.pipeline:124]: Decoded audio has 2 channels, 44100 Hz sample rate, and 16 bits per sample
[12:44:46.383][D][ring_buffer:034]: Created ring buffer with size 192000
[12:44:46.395][D][resampler_speaker:064]: Starting resampler task
[12:44:46.405][D][resampler_speaker:085]: Started resampler task
[12:44:46.411][D][ring_buffer:034][sample]: Created ring buffer with size 176400
[12:44:46.419][D][speaker_mixer:316]: Starting speaker mixer
[12:44:46.428][D][speaker_mixer:324]: Started speaker mixer
[12:44:46.448][D][ring_buffer:034][speaker_task]: Created ring buffer with size 96000
[12:44:46.448][D][i2s_audio.speaker:102]: Starting
[12:44:46.448][D][i2s_audio.speaker:106]: Started
