Using Inspiration from here for wiring:
I have managed to make my dumb diffuser into a smart one with a D1 Mini + ESPHome!
Parts (so far)
Wemos D1 Mini
100 ohm resistor
Wire
Optocoupler PC817
Working:
On (mimics 1 button press)
Off (mimics a further 4 button presses)
ON/OFF State (Reads Voltage via ADC pin to + pin on Ultrasonic Disc)
To do (help appreciated)
LED control (runs off a rotary encoder - need to work out how to mimic the output of this with the D1 mini to control LED light)
ESPHome Code:
## ESPHome
esphome:
friendly_name: fragrance-diffuser
esp8266:
board: esp01_1m
## Log Settings
logger:
level: DEBUG
## Home Assistant API
api:
encryption:
key: "here"
## Enable OTA
ota:
- platform: esphome
password: "here"
## WIFI Settings
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Fragrance-Diffuser"
password: "here"
captive_portal:
## Web Server
web_server:
port: 80
version: 3
## GPIO Relay Switch + Template Switch
switch:
- platform: gpio
pin: GPIO4
icon: 'mdi:light-switch'
internal: True
on_turn_on:
- delay: 100ms
- switch.turn_off: relay
icon: 'mdi:scent'
lambda: |-
if (id(binary_switch).state) {
return true;
} else {
return false;
turn_on_action:
- switch.turn_on: relay
turn_off_action:
then:
- if:
condition:
binary_sensor.is_on: binary_switch
then:
- delay: 500ms
- delay: 500ms
- delay: 500ms
## Voltage Sensor
binary_sensor:
icon: 'mdi:power'
- platform: adc
pin: A0
internal: True
update_interval: 5s
filters:
- multiply: 3.3
on_value_range:
- above: 0.01
then:
- binary_sensor.template.publish:
state: ON
- below: 0.01
then:
state: OFF
I will add more photos and information on wiring later
Any help with how to control LED light would be great! Plan on measuring remaining pins on the rotary encoder to see what they read when being turned.
