💡 The Everything Light - Trigger a light any way and turn it on in any way
Hi Freddeh,
Thanks for this feedback.
Seems to be a fair observation, so I’ll modify this for the next release.
Yes, the nature of dynamic mode is that you can set the maximum or minimum brightness to 0% (effectively turning it off). You can prevent this from happening by choosing other values or changing the values for ‘over max’ and ‘under min’. See screen capture below.
