The following compnents and platforms could not be set up:* platform
I was making some changes and now my history shows “invalid config” with status unknown and “The following compnents and platforms could not be set up:* platform” message. I think I reversed all changes, but still have this message and it shows that it is still active.
If I click on the button Check Configuration, it says Valid.
Can someone help me with this? Maybe, if you have the original configuration.yaml file, so I could try to find what is wrong with my file?
Thank you.
If you just move your configuration files out of the .homeassitant directory, HA will create the default one when it starts up.
Thank you for your advice, but it did not create the new configuration file.
And still keeps the history and looks like it is still active.
Thank you.
I was wrong, it created new file, but the error is still there.
Thank you.
