dramatic music
{bat sense begins to tingle}
dramatic music
Comment Removed.
So mark the yaml-dropping Components just like cloud-polling / local-polling are marked. Let us see which components are dropping Yaml. Shoot, let us filter the list so weâre not even distracted by those for whom yaml is sigh oh so burdensome.
One thing I donât like is when you setup an integration only to find out the configuration has failed even if you followed the documented configuration and have to restart Home Assistant 3 more times to get it working right.
It makes my zwave network very unhappy. So I welcome anything that causes me to have to restart Home Assistant.
So you have this nice thing.
You want to grow this nice thing because if you donât it tends to stagnate and die.
Understandable.
Pissing off a large section of your loyal user-base to grow the nice thing?
Unfortunately that has to be done sometimes simply due to practicalities.
You have to be very careful about choosing your new target demographic though. For example:
By dumbing down the nice thing you are going to attract a lot more dummies. And the situation shown in that comic is going to become more common, not less.
Ask yourself, do you really want Home Assistant to be used by people who would have trouble setting a clock on a microwave oven?
This is all a bit rambling and I do have to admit that so far the shift away from YAML has not affected me adversely. I can only remember one or two occasions where I had to delve into the undocumented .storage
black box to fix things that were not fixable via the UI. That was in the early days though and I have not had to do this lately. I do actually like discovery and the way my commercial and DIY devices seamlessly integrate into Home Assistant.
One thing that has become slightly more difficult is community support. Rather than asking for correctly formatted configuration code so it can be easily cut/pasted/corrected I find I have to post more screenshots edited to show a button press procedure. This is time consuming and tedious but Iâm not forced to do it. So I may just end up doing less.
Also I learned YAML and it was surprisingly easy. So new users should have to learn it as well. Now get the hell off my lawn. ~ Wanders away yelling at clouds
~ /jk
But seriously, I find it more efficient to define automations and scripts in YAML and JINJA than the UI and if the current ADR ever changes to exclude that I would have to re-evaluate my use of Home Assistant. It is good to hear there are currently no plans to remove this.
Same even though I use Lovelace in Storage mode and I maintain lovelace in yaml and use cut/paste so I kinda get the best of both methods. I have pretty much switched to everything via GUI except scripts/automations and when GUI adds new support for integrations I switch to use them. I donât see a good reason not to use the GUI where possible for that kind of stuff.
I forgot about the the front end. Yes this is the best of both worlds.
4 posts were split to a new topic: Problems with WLED and ESPHOME integrations
I have an example of needing to do thisâŚ
A few weeks ago after an update/restart my frontend wouldnât load (of course I did a config check first just like every other time!) and I started getting errors in my log about the HACS component (along with a lot of other related/unrelated things). And of course we all know that the first recommended troubleshooting step is to remove the offending custom component (it says so right there in the first lines of the log).
The problem was that I had HACS configured via the UI at some point and because I didnât have access to the front end I couldnât remove it via the UI. I was then pretty much stuck. It literally took several hours of troubleshooting/editing the .storage files to purge them of anything HACS related/etc. until it was all back up and running again. I even eventually had to create an entirely different virgin HA docker container and added things back a bit at a time from my original config until I âfoundâ the issue.
SoâŚwithout being able to edit those mostly not-easily-readable JSON files and then knowing how things were supposed to work in the first place because I usually configure (mostlyâŚ) everything in yaml I would have ended up needing to completely restart my main config from scratch. And even with my experience with things HA related I was still unsure about where all the bits of the HACS integration were spread out in the .storage files.
I still donât know why things got broken like they did but Iâm fairly confident in saying that if I was one of the newly-targeted ânon-tech savvyâ users I would have been completely lost on how to proceed to fix things. And having everything configured in the âblack-boxâ of the hidden .storage files only adds to that.
And since there is no âcustomer serviceâ that the non-tech savvy user can reach out to for help they will come here. Then we are supposed to try to help them fix their broken systems by telling themâŚwhat exactly? To use SSH/SAMBA (which they probably donât know how to use and havenât ever got it set up) and go into their .storage files and edit those un-editable files that are written in unreadable JSON and to delete every reference to some UI configured integration that might be spread across several files? But "oh, yeahâŚmake sure you donât mess up the syntax of those mysterious files because if you do all hope is lost for ever fixing it without starting completely from scratch. But, hey, no pressure. âWait, you didnât make a backup?â Of course not. And why would they since the new target user is not tech savvyâŚ
TBH, thatâs kind of where Iâm headed right now.
EDIT:
It would be interesting to see where HA would end up if all of the âpower usersâ stopped interacting on the forums trying to help out all of the new target ânon-tech savvyâ users when things break and they werenât here to hold the new users hands thru fixing it.
absolutely
I much prefer using YAML for as many things as possible being that is how I learnt how to use HA. I find it simple now, and mostly easy to troubleshoot.
I can see how for new users having an idiot-proof setup via integration makes life easy getting things to workâŚuntil it doesnât.
Well, I try to get as much of them out of yaml. It sometimes needs some json crafting to create discovery messages, but it is doable.
My 2 cents: sure, itâs not my preferred solution. But I want my family to use HA as well and they can absolutely not be trusted with YAML files. I want HA to grow, I accept the devs decision and Iâll make the integration that I help maintain ready for UI.
(edit: must have pressed the wrong button, this was not meant as a reply to @kanga_who)
Is it the time for a new fork?
There have been more and more changes recently that do not sit well with current users.
Do I smell something similar to emby/jellyfin?
Hopefully not. Weâre mostly users, not developers.
So donât give them access. Pretty simple. I donât trust my wife with any admin functions, hence why her account is a user account.
Iâm sorry all the cobol programmers are busy fixing the US unemployment systems for the foreseeable future.
Yeah but IBM are doing lessons to bring the workforce up to speed.
I mean, I want them to use it in their place, I donât live with them . Biggest threat is that theyâll move to some closed solution.
