dxdn
1
i dont know why i only see in the energy graph only data-points. (Measure: power (watt))
Why the points a not connected/draw with a line?
- name: "Strom aktuell_lokal"
unit_of_measurement: "W"
device_class: "power"
state_class: "measurement"
state: >
{{ (states('sensor.poweropti_local_nurleistung')|from_json).Watt }}
tom_l
2
Because your sensor is unavailable for nearly 100% of the time. Your log is likely full of errors about this.
Also that is not energy. That is power. Two different thing.
dxdn
3
this is my Log from the Sensor.
tom_l
4
That is your logbook. The the log I was talking about is at Settings → System → Logs.
Either way, yes your sensor is unavailable most of the time. You should fix that.
