🎉 The Home Assistant BACnet integration is now officially included in the default HACS store and v1.0.55 is live!
Being part of the default store also means the integration passed the HACS review, and updates show up automatically for everyone
What’s new since v1.0.50?
  • Energy dashboard: water and gas meters can now be added to the Energy dashboard. Pick “Water meter” or “Gas meter” per object, and flow rates (L/h, mÂł/h, etc) work as live flow out of the box.
  • More units: L/h, mÂł/s, mÂł/min, gallons, cubic feet, joules and more are now recognized, so these values get the right unit and statistics.
  • Long-term statistics: energy and volume meters are stored as real meters, and you can set the state class per object.
  • Large devices: a searchable object list, importing all objects of a type in one click, and a clearer rescan to add or remove objects.
  • Easier settings: the options now open with a simple menu: Settings, Rescan device and Customize objects.
  • Autodiscovery: device search now also works with an empty local IP address or one without subnet notation, and it reuses the existing connection.
  • Cleaner values: NaN and infinite values show as unknown instead of causing errors, and writable values no longer show long rounding tails like 1.43999993801117.
  • Privacy: sharing usage statistics is opt-in and off by default. If you do tick it, you help the list of tested devices grow.
All about the integration, including installation:
Release notes:
Curious about which devices have been tested? Check out the list:
Share and like this post to help others discover this integration!
