The icon does not change and only the eye is displayed
I have the meter values in the overview and would like to change the color as well as the icon at the state: sensor.evu_current_power depending on the current power consumption.
The coloring of the text works so far. However, the icon does not change and only the eye is displayed.
What am I doing wrong here?
Thanks a lot
The Config:
type: entities
entities:
  - entity: sensor.evu_zahler_export
    icon: mdi:transmission-tower-export
  - entity: sensor.evu_zahler_import
    icon: mdi:transmission-tower-import
  - entity: sensor.evu_aktuelle_leistung
    icon_template: >
      {% if states('sensor.evu_aktuelle_leistung') | float > 0 %}
      {% else %}
      {% endif %}
    card_mod:
      style: |
        :host {
          color: {% if states('sensor.evu_aktuelle_leistung') | float > 0 %}
            red;
          {% else %}
            green;
          {% endif %}
          font-weight: bold;
title: EVU Werte
state_color: true
footer:
  type: graph
  hours_to_show: 6
  detail: 2
Changing icon color is by using the --paper-item-icon-color tag
      style: |
        :host {
          --paper-item-icon-color:...
Like so in your exemple:
    card_mod:
      style: |
        :host {
          color:
              red
            {% else %}
              green
            {% endif %};
          font-weight: bold;
            {% if ('sensor.evu_aktuelle_leistung') | float > 0 %}
              red
            {% else %}
              green
            {% endif %};
For the icon, I think that there is no other choice than to setup a template that encapsulate your sensor.
    sensors:
      evu_aktuelle_leistung_templated:
        friendly_name: EVU aktuelle Leistung
        value_template: "{% states('sensor.evu_aktuelle_leistung') %}"
        icon_template: >
          {% else %}
          {% endif %}
And use it in your entity card instead of sensor.evu_aktuelle_leistung
You are trying to use an option which does not belong to Entities card.
Check card-mod and “—card-mod-icon” variable.
You’re correct.
However, I tend to lean towards official solutions whenever possible because they are typically more sustainable in the long run.
I only resort to using card-mod when there are no native options available.
It’s frustrating how often I’ve had to update my card-mod configurations due to changes in the underlying CSS.
Depends on a particular card-mod code.
@Ildar_Gabdullin
Thanks for the help.
This is how it works now. At the same time I have also colored the icon.
Is there a way to bundle options here? Currently with this solution I have to do the same query for each option.
Thanks a lot
type: entities
entities:
    icon_template: |-
      {% else %}
      {% endif %}
    card_mod:
      style: |
        :host {
            red;
          {% else %}
            green;
          {% endif %}
          --card-mod-icon: {% if states('sensor.evu_aktuelle_leistung') | float > 0 %}
            mdi:transmission-tower-import;
          {% else %}
            mdi:transmission-tower-export;
          {% endif %}
          --card-mod-icon-color: {% if states('sensor.evu_aktuelle_leistung') | float > 0 %}
            red;
          {% else %}
            green;
          {% endif %}
          font-weight: bold;
title: EVU Werte
state_color: true
footer:
  type: graph
  hours_to_show: 6
  detail: 2
Already told you - this is wrong, check above, unsupported option.
Also, instead of using css variables “-color” you may explicitly change particular css properties for particular Dom elements. Go to huge card mod thread → 1st post for details.
Also, about changing an icon. If you need to change an icon for this entity EVERYWHRE (not in some particular card) - consider either a templated icon (if this is a template sensor) or a Custom UI (for other entities).
tbh, a power sensor should really just get device_class: power and probably a state_class: measurement if you want Long term stats (LTS) on it.
it will auto set the correct power icon because of the device_class.
no required custom (card_mod/custom-ui) settings at all for that. core does it all on those.
if you really want the templates to change them, then yes, you the template also on the icon:
which is really easy when using a core template entity, but this apparently isnt.
your next options are templating dashboard cards (also custom, because core does not support that)
or use custom-ui which is very powerful, I’d be glad to help you out, but need you to be sure you want it, I am reluctant to advise you to use custom-ui. its great, but can break upon each and every update of core. We just had an update to fix the Dom path in more-info… so no promises made
Sorry, I have correct it :wink:
This is the final code:
type: entities
entities:
    icon: |-
      {% else %}
      {% endif %}
    card_mod:
      style: |
        :host {
           color: red; --card-mod-icon: mdi:transmission-tower-import; --card-mod-icon-color: red;
          {% else %}
            color: green; --card-mod-icon: mdi:transmission-tower-export; --card-mod-icon-color: green;
          {% endif %}
          font-weight: bold;
title: EVU Werte
state_color: true
footer:
  type: graph
  hours_to_show: 6
  detail: 2
Icon option does not support templates.
