The Jewish calendar add on is displaying hours to an event rather time of event, how to change?
I am trying to use the Jewish calendar plugin, but the results are being displayed as hours rather than time.
For example, there is candle lighting time, rather than showing the time, it’s showing that there are 6 hours left.
Any suggestions?
integration? If so, there’s a ton of different sensors it creates. Are you sure you’re looking at the correct one?
Also, the UI will show it as a relative time. The time ‘under the hood’ is a datetime. You can convert it to any timestamp you want using a template sensor.
Check out the state in the developer tools -> states page. A template like this will give you HH:MM
as_timestamp(states('sensor.upcoming_candle_lighting')) | timestamp_custom('%H:%M')
Thank you.
I put in the sensor of “sensor.jewish_calendar_upcoming_shabbat_candle_lighting”
and its displaying hours to instead of the time of.
Where would I add that template?
Thank you
in a template sensor
add to lovelace:
format: time
for example:
entities:
  - entity: sensor.jewish_calendar_date
  - entity: sensor.jewish_calendar_parshat_hashavua
  - entity: sensor.jewish_calendar_alot_hashachar
    format: time
  - entity: sensor.jewish_calendar_latest_time_for_shma_gr_a
    name: סוף זמן ק"ש
    format: time
  - entity: sensor.jewish_calendar_plag_hamincha
    format: time
  - entity: sensor.jewish_calendar_shkia
    icon: 'hass:weather-sunset'
    format: time
  - entity: sensor.jewish_calendar_t_set_hakochavim
    icon: 'hass:weather-night'
    format: time
  - entity: binary_sensor.jewish_calendar_issur_melacha_in_effect
  - entity: sensor.jewish_calendar_upcoming_candle_lighting
    format: time
  - entity: sensor.jewish_calendar_upcoming_havdalah
    format: time
Hi @yonanavon This is an old thread but still useful for what I’m looking for.
Perhaps you guide me as to where to input this code to add the time format?
