Hi, everyone!
I am thinking to build the most accurate room presence system and I need some ideas. First of all, I started thinking about motion sensors and many many rules in home assistant, by mounting one motion sensor in every room, then some rules similar like: If sensor from the lobby has been detected a movement then in maximum 5 seconds, the sensor from room 1 senses movement = I’m in that room, and so on, many rules to know where you are in the last moment, but if there are many people in the house, the rules will do wrong with everything and you will not know where is exactly in the room, because the sensor are detecting something everytime, mostly because there will be movement…
For the most accurate room presence, I think I will need two IR Beam Sensors with 433hz or zigbee transmitter, to every door. There should be a distance at least 3-5 cm between the pair of IR Beam Sensors… and with this system and some rules, you can detect if someone is inside of a room or he/she gone outside of that room… The rules for a door should be something like: If sensor one is triggered, then sensor two, you got in the room… If sensor two is triggered first then sensor one, you went outside the room…
Now, the ideal hardware IR or Laser Beam sensor, from my opinion, should be something which have already a 433 or zigbee transmitter which sends datas everytime when it is triggered, and of course, working with batteries…
Till now, I only found the IR/Laser beam sensor separately, then the 433mhz transmitter, and all are working with a power adapter of 3-5-6-9-12V, not with batteries…
Any ideas? Please avoid to tell me anything about bluetooth presence, door sensor, wireless presence, tags, low gps or something which is not too accurate…
