hello.
when i still had my old phone i couldn’t connect the app to my home assistant. it kept giving me an error: failed to perform SSL handshake.
then the old phone (or rather its screen) bit the dust, and i got a new one. weirdly enough, the problem was gone, and i could use the app on my new phone with no problem. that is, until a few days ago. now it refuses to connect unless i’m on my own wifi, and it gives me the same error again. no, i did not change the connectivity settings or the configuration of my LAN. it just stopped working
any ideas what i can try? has anyone found a solution to this problem?
duckdns and lets encrypt, as described in this video: https://www.youtube.com/watch?v=AK5E2T5tWyM
when i got my new phone, it worked ok for a while, then it went intermittent for a few days, then it stopped working.
so until this is fixed, i’ll have to use unifi to detect if i’m at home or not. kinda works but is not as reliable as using the app.
You have an issue with the SSL connection and most likely it is related to your certificate.
make sure that the certificate is up to date and that all services are using the correct one.
You might connect directly to HA on the home network, but through the NGINX proxy from outside.
Try to connect to the homepage first and see what the browser thinks of the certificate.
Usually the browser provide a view of the security settings for a site by clicking the icons next to the URL.
tried chrome, got the same result. but i noticed something: when i tried to connect via the mobile phone network, i got “unable to connect. retrying in…” (as expected) but i still got the lock in the URL field. weird. then i tried the same in firefox, and i got the lock there too. that tells me that the issue is either in my server or on my phone, not somewhere inbetween.
