The power wheel and power to energy calculation
Hereby the my integration of the HACS Power Wheel and the calculation of the energy (kWh) from the measured solar power.
My first issue was that I only measure the power (kW) of my solar panel I found the following python script.
Energy Python Script (kW to kWh)
I adjusted the number of decimal in the script. Because it is using input_number variable instead of sensor I had to add a automisation to copy the sensor value to the input_number
- id: 'tranfer data solar'
  alias: move solar data
    - platform: state
      entity_id: sensor.solar_pv_power
    service: input_number.set_value
    data_template:
      entity_id: input_number.solar_power
      value: "{{ states('sensor.solar_pv_power')|float }}"
- alias: Energy Integration Solar
  initial_state: True
    - platform: state
    service: script.turn_on
    entity_id: script.solarenergy
This resulted in the following pictures :slight_smile:
HA_Energy Distribution
HA_Power distribution
HA_netenergy
HA_nettpowetJPG
