I have two “scrape” sensors listed in my Configuration.yaml file. I just received the “The Scrape YAML configuration has been moved” warning which states to migrate the YAML configuration to the integration key according to the documentation, but doesnt provide a link to the documentation.
Can anyone provide insight as to what this warning actually means and how to go about fixing it? I would really rather not lose access to my scraped sensors.
So there is actually a “Scrape” integration that you can add to Home Assistant. It then lists all the items you need to fill out (copy paste from your yaml scrape setup) and it should work.
Invalid config for [scrape]: [authentication] is an invalid option for [scrape]. Check: scrape->scrape->0->sensor->0->authentication. (See /config/configuration.yaml, line 71).
Can I also use authentication with the new style?
The documentation says it should work…
